Check Engine Light 61
Old Sep 2, 2008 | 06:35 PM
dvonghalath's Avatar
Default Check Engine Light 61
I have a 97 civic and when i was driving one day the check engine light came on. I checked the code and it gave me a code 61 which is the primary oxygen sensor...im not that good with cars. Where does code 61(primary O2 sensor) located? When i disconnected the batteries, the code was gone and it returns comple days later...is there something else wrong. And when the check engine light comes on the car drops in rpm and rise...
Any help would be grateful....
Old Sep 2, 2008 | 06:41 PM
skate_volcom2006's Avatar
Default Re: Check Engine Light 61 (dvonghalath)
O2 sensor on your exhaust manifold. More then likely you need a new one if it takes the CEL a little while to come one. I would recomend a Bosch.
Old Sep 2, 2008 | 06:46 PM
94EG8's Avatar
Seagull Management
Default Re: Check Engine Light 61 (skate_volcom2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skate_volcom2006 &raquo;</TD></TR><TR><TD CLASS="quote">O2 sensor on your exhaust manifold. More then likely you need a new one if it takes the CEL a little while to come one. I would recomend a Bosch.</TD></TR></TABLE>
Yeah, thats sounds about right, bosch O2 sensors suck though, Denso or NTK are the way to go IMO.
Old Sep 2, 2008 | 07:23 PM
Default Re: Check Engine Light 61 (94EG8)
The O2 sensor that i need to replace is on the header towards the top and not from the catalyac converter on the bottom?
Old Sep 2, 2008 | 07:28 PM
Yes directly on your header/exhaust manifold. The one by your cat is your Secondary o2.
Old Sep 2, 2008 | 07:31 PM
cool ill try to replace it 2moro and see wat happens.
jjenkins
Mar 6, 2010 08:37 PM
slim689
Apr 19, 2007 10:55 AM
Mad Money
Sep 27, 2006 08:22 AM
hondamama7894
Mar 10, 2005 11:05 AM
