speedometer
Old Sep 2, 2008 | 03:56 PM
andrew__g's Avatar
Default speedometer
my speedometer is all over the place. its totally random just seems to bouch around even when im stoped. anyone have any suggestions?
Old Sep 2, 2008 | 04:02 PM
nix94delsol's Avatar
Default Re: speedometer (andrew__g)
too much torque...
jk, haha have you ever taken your needles off?
Old Sep 2, 2008 | 04:33 PM
BlueIntegraBoy's Avatar
Either the VSS going out or the circuit board directly behind the speedometer mechanism is going out.
Old Sep 2, 2008 | 04:37 PM
Default Re: speedometer (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Either the VSS going out or the circuit board directly behind the speedometer mechanism is going out.</TD></TR></TABLE>
i love it when this guy posts
its so straight foreward
VSS was my next idea BTW
Old Sep 2, 2008 | 06:42 PM
boostedhks's Avatar
what is VSS, i got the same problem
Old Sep 2, 2008 | 06:44 PM
94EG8's Avatar
Seagull Management
Default Re: (boostedhks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedhks &raquo;</TD></TR><TR><TD CLASS="quote">what is VSS, i got the same problem</TD></TR></TABLE>
Vehicle Speed Sensor, its bolted to the top of the transmission.
Old Sep 3, 2008 | 09:59 AM
andrew__g's Avatar
is this vvs easy 2 access? is it a do at home fix or get a mechanic to do it?
Old Sep 3, 2008 | 10:36 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrew__g &raquo;</TD></TR><TR><TD CLASS="quote">is this vvs easy 2 access? is it a do at home fix or get a mechanic to do it?</TD></TR></TABLE>
Yes its easy, its just bolted to the transmission with 2 bolts, simeply unplug the VSS, remove the 2 bolts, bolt up the new one and plug it in.
Old Sep 3, 2008 | 03:56 PM
Default Re: speedometer (94EG8)
The whole sensor + gear is held onto the tranny by one 10mm bolt. The sensor is bolted to the bear with 2 bolts.
Old Sep 4, 2008 | 05:42 AM
choadtx's Avatar
New User
I've got a similar problem... The speedometer has been randomly quitting and working again for the past year or so. Now it has finally gone completely out and only works about 1/10th of the time. I put a new VSS in and still no go. I pulled the guage cluster and checked all connecters, still no go. Any ideas what else I can check???
96 civic 5speed...
dylokjai
Dec 2, 2006 06:15 PM
Donkey85
Nov 7, 2003 12:00 PM
SlippylesKB
20
Oct 18, 2003 04:32 PM
degooser
13
Aug 18, 2003 10:57 PM
yellow blur
May 19, 2003 11:02 AM
