SI Cluster help
Old Sep 2, 2008 | 03:13 PM
thaiboiz's Avatar
Default SI Cluster help
I bought the si cluster from someone on ht
I install it today on my 99 civic ex and I notice the problem
here's the problem
before i turn on the ignition the mph needle(middle gauge) stay at 0(which is how it supposed to be) and when i turn on just the ignition(car still off)..the needle go up between 0-10mph mark(the needle not supposed to move up and it should be stay at 0 mark)...after i start the car i notice that the gauge didn't give me the right mph reading...ex. in my 1st gear, when i drove to 2400rpm, the mph needles already at 20mph, and when i get to about 3000rpm..mph needle already at 30mph.....it should be around 5000rpm to get to 30mph....and like if while im driving and i press the brake to the point the car is stopping...the mph needle still havn't go down all the way to 0 yet...it stays between 20-10 mph mark and it move down very very slowly......
Is there a ways to fix this kind of problem...or the cluster is defective??
and do i have the right to refund?
Old Sep 2, 2008 | 03:18 PM
DTA-Zombie's Avatar
Default Re: SI Cluster help (thaiboiz)
get a refund. If your other cluster did not do this most likely could be the cluster or a bad/loose connection
Old Sep 2, 2008 | 03:23 PM
94EG8's Avatar
Seagull Management
previous owner probably had the face off the cluster, maybe to roll back the odometer or maybe to put on different gauge faces and didn't calibrate the speedometer when he was done, thats my guess.
Old Sep 2, 2008 | 04:29 PM
EkB18C5's Avatar
I have an Si cluster in my 97 civic HX, and it works just fine. Just a couple questions....is you car an automatic? Does your stock cluster have all the same gauges that the Si cluster has? Or did your stock cluster not have a tach? Lots of different things can happen when you are monkeying around where your not supposed to. Like the other guy said about pulling the cluster apart to change the faces...some people pull the needles and don't put them back right. Pull it, check all you plugs, compare the two clusters and look for any tampering with the mileage.
Old Sep 2, 2008 | 05:08 PM
thaiboiz's Avatar
Default Re: SI Cluster help (EkB18C5)
the cluster that i got was only 12xxx mile, so u guys might be right.....i'm trying to contact the seller right now...hoping that i will get refund
Old Sep 2, 2008 | 05:14 PM
thaiboiz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkB18C5 &raquo;</TD></TR><TR><TD CLASS="quote">I have an Si cluster in my 97 civic HX, and it works just fine. Just a couple questions....is you car an automatic? Does your stock cluster have all the same gauges that the Si cluster has? Or did your stock cluster not have a tach? Lots of different things can happen when you are monkeying around where your not supposed to. Like the other guy said about pulling the cluster apart to change the faces...some people pull the needles and don't put them back right. Pull it, check all you plugs, compare the two clusters and look for any tampering with the mileage.</TD></TR></TABLE>
My car is 5speed Ex, so it should be the same? but i was wondering something....my car was running EX Auto cluster(the previous owner told me that the original EX Manual cluster doesn't work, so he replaced with the EX Auto b/c he couldn't find the maunual one)....but that cluster work great..not a single problem....but i got extra harness(small orange plug....the same size as green and yellow one) it doesn't have the place to plug in the SI cluster.....i have no idea what it was!!
Old Sep 2, 2008 | 06:56 PM
VjaSMine's Avatar
pop the needle out with a fork, turn the car on, put the needle back in, but dont push it all the way in. take it out and put it back in as needed to set it to 0mph while the car is on. and when you get it right, push it back in. i did it to two clusters already and it worked like a charm
Old Sep 2, 2008 | 07:32 PM
thaiboiz's Avatar
Default Re: (VjaSMine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VjaSMine &raquo;</TD></TR><TR><TD CLASS="quote">pop the needle out with a fork, turn the car on, put the needle back in, but dont push it all the way in. take it out and put it back in as needed to set it to 0mph while the car is on. and when you get it right, push it back in. i did it to two clusters already and it worked like a charm</TD></TR></TABLE>
i will try it...so all i got to do is pull needle out with a fork?? is it hard to come out??
ok thanks man
Old Sep 2, 2008 | 08:16 PM
Frozen E's Avatar
H-T White Ops
Default FV-QR
Be careful with that needle. It's real easy to break the metal part that it hooks up to. If you don't pull up perfectly straight you CAN break that and then you'll have to buy another $100+ spedometer assembly.
Old Sep 2, 2008 | 10:00 PM
thaiboiz's Avatar
Default Re: FV-QR (IslandSi)
hmmm...i ask my friend to drive the lane next to me...and test to see if my cluster read the right speed....i drove around 40-friend car was like 35, drove 50-friend was like 40, drive 60 was like 50 in friend car....so it off like 10
i already took out the needle...will try to adjust it tomorrow...was sweating alot trying to take out that needle..but finally pops out..thanks guy
Old Sep 2, 2008 | 10:05 PM
Frozen E's Avatar
H-T White Ops
Default FV-QR
What I had to do:
Install the needle UNDER the little plastic stopped thing and then gently bent it up so it would get over the stopper. It's pretty much right on now. It's a trial and error thing. You may want to think about temporarily removing that little black stopper thing to make fine tuning easier.
Old Sep 2, 2008 | 10:21 PM
thaiboiz's Avatar
so if i set it up to 0, i might make an error also...like it might show that i drive 10mph, ithe actually speed could be 15mph......so the needle should be under the stopper and pointing 0 right?
man this is really crazy
i have thought about this along time ago...like i always wondering if it posible to just get the si gauge face and swap in ex cluster....i never thought it possible coz i thought it might give the wrong reading...but never know that we can manually adjust the needle...this is really crazy lol
Old Sep 2, 2008 | 11:12 PM
Frozen E's Avatar
H-T White Ops
Default FV-QR
Si gauge face on EX cluster will be totally jacked up.
The mechanics will still be EX but the display will be Si. Not going to work. Well, it'll work, but it won't be anywhere near accurate.
Old Sep 3, 2008 | 09:12 PM
thaiboiz's Avatar
i adjust it today...but still feel like little bit off
1999jdm
11
Apr 17, 2013 04:22 AM
SpeedoKing
Jun 26, 2008 04:47 PM
kaboomwoom
Mar 12, 2008 01:06 AM
GreddyCivic7
26
Apr 11, 2007 03:38 PM
