clutch and flywheel
Old Sep 2, 2008 | 02:50 PM
95_red_dc's Avatar
Default clutch and flywheel
I am installing a new competition clutch stage 4 and a fidanza flywheel on my 95 gsr. I have the flywheel bolted up and I'm trying to get the pressure plate bolted up to the flywheel but the alignment pins wont go through the pressure plate hole.Has anyone had this problem? How do you know which way the 6 puck disk needs to face? What parts store carry the pressure plate bolts?
Old Sep 2, 2008 | 03:29 PM
Kendall's Avatar
Very simple. Rotate the pressure plate until you find the correct alignment. It only goes on one way. The disk won't make contact with the flywheel if it's in backwards.
Old Sep 2, 2008 | 06:19 PM
Circusraven's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Very simple. Rotate the pressure plate until you find the correct alignment. It only goes on one way. The disk won't make contact with the flywheel if it's in backwards.</TD></TR></TABLE>
I second that
dtme46
Mar 7, 2009 11:07 PM
95_red_dc
Transmission & Drivetrain
Sep 5, 2008 02:38 AM
1.8L_allmotormilitia
May 25, 2007 02:33 PM
boosted350z
Nov 27, 2004 06:49 AM
luderone
Sep 13, 2003 02:01 PM
