12lbs flywheel
Old Sep 2, 2008 | 02:25 PM
NY-Trizz's Avatar
Default 12lbs flywheel
I recently installed a stage 2 exedy clutch with a 12lbs flywheel...for some reason my vtech doesn't seem to be kicking in...is it just me or what??
Old Sep 2, 2008 | 06:07 PM
vtecb18c's Avatar
Default Re: 12lbs flywheel (NY-Trizz)
replacing the clutch and flywheel is not going to make your vtec not engage..did you unplug anything? is your speedo working?
Old Sep 2, 2008 | 06:20 PM
Acidcrakker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NY-Trizz &raquo;</TD></TR><TR><TD CLASS="quote">I recently installed a stage 2 exedy clutch with a 12lbs flywheel...for some reason my vtech doesn't seem to be kicking in...is it just me or what??</TD></TR></TABLE>
Yeah installing a flywheel and clutch on your telephone wont enable vtech.
All kidding aside why do you have a stage 2 clutch. Im assuming you have a stock motor with mild bolt ons
Old Sep 2, 2008 | 06:21 PM
98vtec's Avatar
moderator emeritus
Default Re: 12lbs flywheel (Acidcrakker)
did you plug the vss back in?
Old Sep 2, 2008 | 08:10 PM
Speedra500's Avatar
Default Re: 12lbs flywheel (98vtec)
check your vss, vtec solenoid, vtec pressure switch, and coolant sensor and make sure they are undamaged and plugged in
Old Sep 3, 2008 | 08:59 AM
Default Re: 12lbs flywheel (Speedra500)
Im pretty sure if he forgot to plug any of those sensors in he would throw a code.....
Old Sep 3, 2008 | 09:05 AM
98vtec's Avatar
moderator emeritus
maybe he didnt put 2 and 2 together.
Old Sep 3, 2008 | 09:15 AM
OBDII Integra
Sep 30, 2009 04:04 PM
b16hybridsol
Honda S2000
12
Jul 3, 2008 11:57 AM
Duck Sauce
May 18, 2008 10:43 AM
theo99gsr
Aug 1, 2005 06:54 AM
vtec-outlaw
Feb 6, 2002 02:27 PM
