Butterfly valve removal? (HELP!)
Old Sep 2, 2008 | 10:46 AM
scspeed's Avatar
Default Butterfly valve removal? (HELP!)
Is it posable?? I have a boosted gsr and don't want to tune unless it is either out or if i completely buy a different intake mani because wont not using the butterfly valve make it hard to tune and restrict alot of power??
If i can take it out how easy is it?? Is it worth it??
Old Sep 2, 2008 | 10:49 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Butterfly valve removal? (scspeed)
You have a boosted GS-R but don't want to get it tuned.
Stop being such a cheap@$$ and get it tuned properly. Anything else you do is probably going to be crap without a proper tune.
Along with having a car that wasn't forced induction from the factory comes the need to do things differently than if it were still N/A. Get it properly tuned and dialed in and you'll be much better off.
Old Sep 2, 2008 | 11:55 AM
Mr.x's Avatar
Default Re: Butterfly valve removal? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">You have a boosted GS-R but don't want to get it tuned. </TD></TR></TABLE>
I think you should read the post, He wants to tune it but he won't unless he gets a new manifold or can remove the butterflies from the stock one. So he wants to know if it is easy to remove the butterflies cause if it's not, he will just go out and buy one then tune......
Old Sep 2, 2008 | 11:57 AM
racebum's Avatar
Default Re: Butterfly valve removal? (Mr.x)
boosting a car without addressing the fuel or timing..hmm..i wouldn't worry since your car won't be alive long enough to worry about. carry on
Old Sep 2, 2008 | 12:50 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.x &raquo;</TD></TR><TR><TD CLASS="quote">
I think you should read the post, He wants to tune it but he won't unless he gets a new manifold or can remove the butterflies from the stock one. So he wants to know if it is easy to remove the butterflies cause if it's not, he will just go out and buy one then tune...... </TD></TR></TABLE>
Or perhaps you should read the post
He's also asking if using the IAB will make it hard to tune or not. And then if so, can he just take them out.
OP I'm sure there are people who run turbo B18C's with the dual runner intake manifold. But many people opt to run a single-runner mani like the Skunk2 or other brands. Of course when doing that, you'll need to run a different ECU.
Old Sep 2, 2008 | 03:58 PM
racebum's Avatar
i missed that myself...oops
Old Sep 2, 2008 | 04:19 PM
Dogginator's Avatar
Daisy... Daisy...
OP, if you disconnect the IAB solenoid, the butterfly valves will always be open. If you absolutely want to remove them, you can. See the following diagram.
http://www.hondapartsunlimited...20All
You can unscrew the buttlerfly plates from their attachment bar. IMO, it is not worth the effort.
jus_spooln_wicha
Mar 18, 2007 06:24 PM
ahemming06
May 12, 2006 12:41 PM
meotch
Mar 16, 2006 12:41 PM
BLK99VTECR
Mar 1, 2004 05:13 AM
4doorsi
Jul 12, 2003 06:51 PM
