Weird hesitation...
Old Jul 24, 2002 | 02:15 PM
pelotudo's Avatar
Default Weird hesitation...
This has happened to me a couple of times now, and I can't figure out what it is.
Keeping a steady 4k in 1st/2nd gear, I will get like 5 small misses in a row and lose power. It will happen quickly and then go back to normal like nothing happened.
I just replaced the cap/rotor about 3 months ago, and was having some problems with the rotor screw coming out...It's now thredlocked in there. Plugs were changed (NGK BKR6E-11's) about 2 months ago.
My first guess would be the rotor in the dizzy...but that thing is tight. I pulled the plugs, and they are a greyish color (NGK normal color), so I am not sure what it could be. I am also getting a little bit of hesitation when taking off at about 4k in 2nd/3rd, and when I let off the gas it jerks a little bit then starts going down smoothly.
Any suggestions?
jB
Old Jul 24, 2002 | 03:56 PM
SuperCivic's Avatar
Default Re: Weird hesitation... (PeloTudo)
which motor?
Old Jul 24, 2002 | 04:12 PM
FUP23's Avatar
New User
Timing....Might wanna check it ...Could be to far advanced or vice versa..just check it ...its a start
Old Jul 24, 2002 | 05:15 PM
pelotudo's Avatar
Default Re: Weird hesitation... (SuperCivic)
90 CRX Si/B16a-I/H/E....NAWWWWWWWSSSSSS.
I checked the cap/rotor and it's still tight. Timing was set to 13btdc about 3 weeks ago (For the n2o).
The wires on top of my dizzy....well, lets just say they're not in the best of shape. I'll take a pic so you guys can see..... They're soddered though, so I thought they would be okay. (When I installed my tach, I stripped the rubber off the wire going all the way in to the dizzy...so there is no rubber outside...just about an inch of open wire coming from the dizzy, soddered to a 6" wire that is then soddered to the wire on top of the dizzy going to the tach. My remote start wire and my Autometer wire are both spliced off that and soddered also...).
In order to check it, would I just touch the ground (meter) to the car and pos to that wire, or do I have to ground to another wire coming out of the dizzy?
As far as maybe being a fuel problem, how could I access that and a fix?
jB
Old Jul 24, 2002 | 06:06 PM
Louie B.'s Avatar
I've started getting the same problem since I did an mpfi swap on my std.
Old Jul 24, 2002 | 06:09 PM
SJP0tato's Avatar
How old is your swap? Has it always done this, or is it just a new development? The symptoms you're describing sound an awful lot like the o2 sensors are switched. You might want to try swapping them around and see if that fixes the problem.
Good luck,
RYan P.
Old Jul 24, 2002 | 06:30 PM
pelotudo's Avatar
Default Re: Weird hesitation... (SJP0tato)
Swap has been in there about year and couple of months. I bought the car in December, and it had been in the car about 8 months.
Going down the freeway, it would hesitate every couple of seconds...Not really miss, you could feel it pulsating at it lost/gained power. Like going up a hill, you could notice it more. It has been doing it a little bit since I got the car. I did fuel injection cleaner, tuneup, etc to it and it went away for a while but came back.
I switched the o2's last week, and it ran like CRAP when I did it. It was REALLY jerky, and really rich (according to my "SUPER" accurate A/F guage). The hesitation multiplied too when I switched them...so I switched them back.
jB
Old Jul 25, 2002 | 06:36 AM
SuperCivic's Avatar
on my b16 i had the primary and secondary o2 sensors switched..it cured my hesitation problem, which was very similar to yours..hesitation at light throttle, ie cruising
Old Jul 25, 2002 | 09:11 AM
02WRX's Avatar
I've got the same issue - it's been discussed in a topic titled "Hesitation" recently. Sad to say, but my problem which I thought was fixed seems to be coming back. I changed my 4-1 headers for 4-2-1 & put in my new o2 sensor, only to have the problem start to come back. I'm going to try to replace my o2 sensor again with an extra one I have & see what happens then. If I get the same problem with a 3rd o2 sensor, then I'm going to have to figure out what would kill an o2 sensor or why the ECU is having problems getting the air/fuel mixture right when in learning mode...
Eric
Old Jul 25, 2002 | 09:41 AM
88_SC_CRX_Si's Avatar
New User
Default Re: Weird hesitation... (90CivicEX)
Has the fuel pump volume been checked? I get the impression of some pump failure, or failing under a load.
Old Jul 25, 2002 | 09:47 AM
SuperCivic's Avatar
it was funny..my hesitation problems were identical to yours..i would also get black carbon on my tail pipe and blow a cloud of black smoke..but when i switched my o2s so the primary was on the driver side and secondary was on battery side it really did cure the hesitation and fix the rich fuel problems.
Old Jul 25, 2002 | 01:40 PM
raene's Avatar
I've got something like that going on... air/fuel stays rich when cruising after the engine has been idling, if you let off the gas so it goes to full lean then it runs in stoich normally until you stop at a light and let it idle again. It kind of jerks when you let off the gas about half a second later, as the air/fuel goes from rich to stoich (hesitates) then drops back to lean.
Reeeeeally weird... I figured it was an IACV problem or a fuel pressure problem... but it seems to do this no matter the fuel pressure.
Kokxxy
Aug 22, 2015 04:01 PM
gtofighter
Jan 7, 2007 09:20 AM
Mr.Death
Jul 29, 2006 02:52 PM
SiR Inspired ED7
May 20, 2005 02:42 PM
