how to tell if injectors are saturated or not....
Old Jul 24, 2002 | 02:12 PM
Blackcivic1's Avatar
Default how to tell if injectors are saturated or not....
how can i tell if they are the saturated kind just by looking...or can i?
Old Jul 24, 2002 | 02:21 PM
gtcali's Avatar
Default Re: how to tell if injectors are saturated or not.... (Blackcivic1)
Ohm meter.
around 3 ohms for peak hold (low impedence injectors)
over 10 ohms for saturated (high impence injectors).
Old Jul 24, 2002 | 09:28 PM
Default Re: how to tell if injectors are saturated or not.... (gtcali)
is there an easyer way? what would happen if you put the peak hold injectors in without a resister box?
Old Jul 24, 2002 | 09:40 PM
PrecisionH23a's Avatar
the ohm test is the best way, if you are too lazy you can call up rc engineering and ask them what type you have. (310) 320-2277, located in cali
Old Jul 24, 2002 | 10:12 PM
Sonny's Avatar
Easier way? Man, it don't get any easier than that!
Sonny
Old Jul 25, 2002 | 07:13 AM
dbman96's Avatar
New User
Default Re: how to tell if injectors are saturated or not.... (Sonny)
Sonny
LMAO. You really should have a multimeter in your toolbox for anything more complicated than changing your oil. If you can't put the probes on the two pins of the injector and measure the resistance... well, you can always just plug them in and start the car. If they're peak/hold, you'll see a little puff of smoke from your ECU. That should make it really clear.
kidd_drastic
Jan 12, 2006 02:18 PM
pissedoffsol
Nov 21, 2003 11:46 AM
zojirushi
Sep 23, 2002 09:01 AM
b20b
Feb 5, 2002 09:14 PM
