gas needle question
Old Sep 1, 2008 | 05:32 PM
ThatGreenGsr's Avatar
Default gas needle question
i was wondering if the gas needle is supposed to go slowly up??? or is it supposed to go up quick when i fill up?? also how many gallons until the gas light turns on?? ive read that its two and some that its when theres only three.
Old Sep 1, 2008 | 07:00 PM
vtecb18c's Avatar
Default Re: gas needle question (ThatGreenGsr)
if the cars on while your filling up than yes but it usually goes up to whatever level pretty quick after you turn your car on
Old Sep 1, 2008 | 10:03 PM
adam081904's Avatar
Default Re: gas needle question (vtecb18c)
Mine goes real slow. 97 gsr
Old Sep 1, 2008 | 10:56 PM
__oversea's Avatar
mine moves around during turn.
so i never get perfect reading.
Old Sep 2, 2008 | 12:57 AM
TOO MUCH TORQUE's Avatar
goes up slow, car fills up 10.5 to 10.9 most of the time.
Old Sep 2, 2008 | 06:23 AM
AWD Terror's Avatar
Default Re: (TOO MUCH TORQUE)
Mine goes up slow after a re-fill.
It is not good to run your gas tank empty. Who knows what crap might be in the bottom of your tank. I usually fill up at 1/4
Old Sep 2, 2008 | 11:02 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Gas light can come on anywhere between 2 to 4 gallons remaining in the tank. It also goes on and off as the fuel sloshes around and moves the floater thingy on the gauge sending unit. When you turn right the floater goes down and makes the light come on. When you turn left, it will go back up and make the light go out.
I try to make mostly left turns only when I get low on gas.
Old Sep 2, 2008 | 03:28 PM
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
I try to make mostly left turns only when I get low on gas. </TD></TR></TABLE>
mine goes up when i make wide left turns or when the street is slanted downhill towards the houses.
Old Sep 2, 2008 | 04:05 PM
Community Builder
yea cuz the gauge sender is on the right side of the tank, so when the car tilts to the right or turns to the left (centrifugal force to the right) it makes the float go higher.
Old Sep 2, 2008 | 05:56 PM
2bk20dc2's Avatar
I'm slack about getting gas....I let the light come on and off...Then when it comes on and stays on, I starting looking to fill up
hannslebo
Jul 4, 2009 10:09 PM
ShinotakuX
Apr 16, 2008 07:54 PM
dmckrazy45
Jul 8, 2006 09:24 AM
S2k Hybrid
Honda S2000
18
Jun 14, 2006 03:55 PM
74celicagt
Feb 2, 2006 06:25 PM
