oil in spark plug
Old Sep 1, 2008 | 03:26 PM
Jokergp's Avatar
Default oil in spark plug
SO i was changing my spark plugs and the ingnation wires when i pulled out the first wire there was oil in it does anyone why????
Old Sep 1, 2008 | 03:45 PM
marquisdee1018's Avatar
Default Re: oil in spark plug (Jokergp)
more than likely,the spark plug seals on the valve cover are worn.
Old Sep 1, 2008 | 05:34 PM
cjo_28's Avatar
What year engine? Or how about, which side of the valve cover are the spark plugs on. The exhaust side (in the front of the valve cover) or the intake side (towards the rear side of the valve cover)?
If the spark plug wires are closer to you, in the front of the valve cover, there is a solid tube pressed into the head. It never leaks. Ever.
If the spark plug wires are on the other side, closer to the intake, the 4 round valve cover seals are often blamed for an oil leak into the spark plug tubes. But these round seals seldom leak oil, no matter how old they are, unless they are torn or damaged
Now, the 4 O-RINGS below the rocker arms leak all the time, and unless you've actually unbolted the rocker arm housing, you've probably never even heard of or seen these o-rings, just like a lot of the guys on this forum.
Old Sep 1, 2008 | 07:29 PM
91h22cb7lx's Avatar
Default Re: oil in spark plug (cjo_28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjo_28 &raquo;</TD></TR><TR><TD CLASS="quote">
Now, the 4 O-RINGS below the rocker arms leak all the time, and unless you've actually unbolted the rocker arm housing, you've probably never even heard of or seen these o-rings, just like a lot of the guys on this forum.</TD></TR></TABLE>
seeing i just happen to have a f22a4 im rebuilding in my garage i thought a pic might help
these are the orings most people just throw away....
Old Sep 3, 2008 | 10:54 AM
hb_guy's Avatar
Default Re: oil in spark plug (91h22cb7lx)
spark plug seals
t0kyoStatus
Nov 26, 2008 07:05 PM
Dj Skidz7
Apr 29, 2008 11:16 AM
braass91
14
Apr 27, 2008 12:03 PM
Red_Si
Oct 26, 2006 10:48 AM
OBDI JEDI
Jun 3, 2003 09:33 AM
