JDM GSR vtec solenoid question
Old Sep 1, 2008 | 02:22 PM
I Like Hondas's Avatar
Default JDM GSR vtec solenoid question
So I just bought my JDM GSR swap off Hmotors and I have this little thing with the vtec solenoid that I just don't get. on my last swap I had a green plug that plugged into the bottom of the the solenoid. On the new GSR which is 0bd2 and is from japland it doesn't have it. I posted pictures. Perhaps someone can shine some light on my problem. The first two pics are the obd2 jdm gsr. the second two are my old b16 head.
Old Sep 1, 2008 | 02:25 PM
slo_hatch's Avatar
Default Re: JDM GSR vtec solenoid question (I Like Hondas)
strange...i thought every vtec solenoid had a green plug?? both of my d series (z6 and y8) have a green plug...as far as EVERY other vtec honda i have ever seen. thats just weird. why not just put another vtec solenoid on it? that should work...right? lol
Old Sep 1, 2008 | 02:28 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: JDM GSR vtec solenoid question (slo_hatch)
IIRC some JDM engines don't have that (VTEC oil pressure?) sensor.
Old Sep 1, 2008 | 02:43 PM
lovelife6431's Avatar
Jdm motors don't use the pressure sensor. So if you get a check engine light for it, All you have to do is splice the power wire for it into the other power wire for the solenoid and ground the other one on the outside of the solenoid... hope this helps
Old Sep 1, 2008 | 02:49 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: JDM GSR vtec solenoid question (lovelife6431)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovelife6431 &raquo;</TD></TR><TR><TD CLASS="quote">Jdm motors don't use the pressure sensor.</TD></TR></TABLE>
I've heard this too, but my JDM engine has that sensor. I thought it was just B18s that didn't have it?
Old Sep 1, 2008 | 03:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovelife6431 &raquo;</TD></TR><TR><TD CLASS="quote">Jdm motors don't use the pressure sensor. So if you get a check engine light for it, All you have to do is splice the power wire for it into the other power wire for the solenoid and ground the other one on the outside of the solenoid... hope this helps </TD></TR></TABLE>This definitely helps. So what would be better at this point, use my b16 one or use the jdm one and hope I don't get a CEL?
Old Sep 1, 2008 | 03:29 PM
DA_9's Avatar
I would ground that wire out and when you tune the car, have them disable the vtec oil pressure from it. I had to do this to my lsvtec when it threw a code and my vtec wasnt working. Have who ever chips your ECUs bypass it; works like a charm.
Old Sep 1, 2008 | 04:22 PM
94EG8's Avatar
Seagull Management
Default Re: JDM GSR vtec solenoid question (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">I've heard this too, but my JDM engine has that sensor. I thought it was just B18s that didn't have it?</TD></TR></TABLE>
According to ff-squad JDM OBD2 B series engines don't have the pressure switch, all other JDM engines do.
Old Sep 1, 2008 | 04:23 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: JDM GSR vtec solenoid question (94EG8)
Thanks
I thought it was something like that but wasn't sure
Old Sep 1, 2008 | 04:27 PM
slvrcvc93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">
According to ff-squad JDM OBD2 B series engines don't have the pressure switch, all other JDM engines do.</TD></TR></TABLE>This is correct a while back I did a write up on the different vtec solenoids and the SoHC on the DOHC motors. That's when I came across the obd2 jdm gsr motors do not have the pressure sensor.
seren8487
Sep 25, 2010 04:21 PM
ekb16
Oct 19, 2005 11:25 PM
CivicEKJDM
39
May 5, 2003 01:12 PM
