Fuel Pump problem
Old Sep 1, 2008 | 01:02 PM
crazyimport's Avatar
Default Fuel Pump problem
Ive been driving my K swapped EG for about a week now, no problems until yesterday.... no fuel prime when i turn the key over....
Tried everything ready to snap and blow up the car
Tried out the relay, tests ok, replaced, still nothing....
Jumped the harness, fuel pump primes 12v signal
Put the relay in no prime or 12v signal to the pump
Fuses ive checked seem to be ok
if i push the key foward alot or let it sit foward the pump will eventually start to prime, but will not start the car..
im to the point where i dont think its the fuel pump or relay, it must not be getting power somewhere else to the relay so its not hitting the fuel relay
any help would be great
Old Sep 1, 2008 | 04:39 PM
Default Re: Fuel Pump problem (crazyimport)
bump
Old Sep 1, 2008 | 05:07 PM
hatchattack92's Avatar
Try doing a continuity test on the wires going to the pump with a DMM. Im just throwing this out there but maybe your ignition switch is bad!
Old Sep 1, 2008 | 05:25 PM
Nic's Avatar
Nic
Default Re: Fuel Pump problem (hatchattack92)
sounds like your ignition switch
Old Sep 1, 2008 | 05:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchattack92 &raquo;</TD></TR><TR><TD CLASS="quote">Try doing a continuity test on the wires going to the pump with a DMM. Im just throwing this out there but maybe your ignition switch is bad!</TD></TR></TABLE>
did a test with it its getting 12v to it no problem so continuity test is ok or it wouldnt be getting power
Old Sep 1, 2008 | 05:38 PM
Default Re: Fuel Pump problem (Nic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nic &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your ignition switch</TD></TR></TABLE>
how do i go about testing the ignition switch????
how do i go about testing the relay connector to make sure everything is getting the proper power/grounds???
Old Sep 2, 2008 | 09:22 AM
bump!!!
datonefoo1
Feb 8, 2008 12:29 PM
thegooddoctorceretti
Audio / Security / Video
Sep 18, 2007 06:27 PM
juanchoenuncrx
Aug 29, 2007 07:59 AM
italstallion
Jul 11, 2006 03:04 PM
2camsaam
Jul 14, 2003 09:09 AM
