Running Rich - VAFC answer?
Old Jul 24, 2002 | 12:23 PM
Civic_Grl_Rcr's Avatar
Default Running Rich - VAFC answer?
118K 94 EXa coupe - Mods that would affect a/f mixture: DC 421, DC exhaust, AEM cai, AEM fuel rail, VENOM Stage I Injectors.
Running rich is, over time, doing nasty things to my O2 sensor and my iac valve (not to mention other things). Would getting a VAFC and learning to "map" my a/f ratio be my answer? I was considering buying an air/fuel autometer gauge to keep an eye on it but if I cannot adjust it then what's the use? So is a V-AFC what I need?
Old Jul 24, 2002 | 12:25 PM
Unjockable's Avatar
New User
Default Re: Running Rich - VAFC answer? (Civic_Grl_Rcr)
I wanna know also.
Old Jul 24, 2002 | 12:31 PM
JaeOne3345's Avatar
why r u running upgraded injectors on those bolt ons? put the stock injectors back in. then see where u r at. autometer a/f gauges only give u a ball park. u need a real wideband o2 sensor to actually tune the a/f ratio
Old Jul 24, 2002 | 12:32 PM
rodrez.'s Avatar
Yes, the VAFC can subtract some fuel and lean you out a little. It would be a good idea to add some kind of gauge or monitor to figure out where you need lose some fuel. Just out of curiosity, why are you running the Venom injectors? Are you squeezing on your motor as well?
Old Jul 24, 2002 | 12:40 PM
Default Re: Running Rich - VAFC answer? (JaeOne3345)
Stock injectors had to be replaced and since I had to spend the money either way and I expect to need larger injectors in the future I went with the slightly larger Venoms. So, putting the stockers back are not an option.
Old Jul 24, 2002 | 12:50 PM
Reid's Avatar
Global Moderator
Get stock injectors.
Your Venom injectors are the cause of the problem.
Old Jul 24, 2002 | 12:56 PM
rodrez.'s Avatar
The best option would be to find a set of stock injectors, used from somebody, have them cleaned up and swap them out. Bigger aftermarket injectors for your bolt-ons are over-kill. Instead of investing in a VAFC, I'd say search for stock injectors. Good luck
Old Jul 24, 2002 | 01:13 PM
brcivic411's Avatar
Default Re: Running Rich - VAFC answer? (rodrez)
i have a set of stock injectors for sale if you're interested
IM or Email me
Old Jul 24, 2002 | 01:17 PM
Kalokohan's Avatar
New User
Get some stock injectors and reset your ecu, you should be fine after that. A VAFC would be nice but not necessary in eliminating you running rich.
sohc steve
May 17, 2005 05:13 PM
b20turbojason
Aug 7, 2004 04:58 PM
gigantor
Nov 11, 2003 07:59 PM
BDTURBO
Feb 27, 2003 10:56 AM
b18c-93
Aug 22, 2002 08:11 PM
