Problem with Oil Pressure
Old Jul 24, 2002 | 11:20 AM
curiousgpnoy's Avatar
Default Problem with Oil Pressure
okay i have just got done turboing my b18 CRX and something tells me im having a problem with oil pressure...cause it seems really low. at idle its like down to 20psi but shoots up like normal when i take off...ideas anyone??? if anyone knows what the normal idle pressure should be then let me know and maybe any problems that you might think i might have...i also have this loud squeeling sound (kinda like rusted or worn out brakes...but louder) but its only when im actually going...does that have anything to do with the turbo??? cause i was thinking maybe it might just be my tranny cause i know its really low on gear oil cause i didnt get to fill it after i slapped it back on...let me know what you think...thanx
Old Jul 24, 2002 | 11:27 AM
quikrpm'z's Avatar
Default Re: Problem with Oil Pressure (curiousgpnoy)
10psi is the lowest it should be at idle, and 50psi @3k. Mines wont go any farther then 50
Old Jul 24, 2002 | 01:11 PM
blmracing's Avatar
that pressure sounds normal to me, my b16 runs about the same at idle.
Old Jul 24, 2002 | 03:36 PM
*Boostwerks*'s Avatar
Default Re: Problem with Oil Pressure (quikrpm'z)
I have my sensor mounted in my Turbo Feed line....
ZC engine
-I have about 9psi at idle(fully warm)
-about 55psi at startup(cold warm up)
-and about 50 psi past 2500RPM
Mine also won't go above 55 though.
Old Jul 24, 2002 | 03:41 PM
quikrpm'z's Avatar
Default Re: Problem with Oil Pressure (Bryson)
how long have u been running the car with that pressure, also what gauge do u have?
Old Jul 24, 2002 | 03:51 PM
Have been running it like that daily for over 8 months.
It is the turbo it self that is giving me the wacky readings
It is a Electical AutoMeter
AsSanitySlipsAway
12
Aug 27, 2006 09:55 AM
integra-modder
Jul 16, 2004 06:44 PM
dominate9
Oct 18, 2003 12:10 AM
Ruby Civic
Sep 2, 2003 03:55 AM
Mugen Dom
Aug 7, 2002 10:37 AM
