H23vtec won't crank
Old Aug 31, 2008 | 01:34 PM
dashocker's Avatar
Default H23vtec won't crank
I have and h23vtec in a 97 civic coupe. The car is getting fuel and spark. I checked the spark pulled the plug and arch to the header bolt. It sparked and tried to start. Put spark plug back in and tried to fire no detonation or spark checked distributor cap. Looked fine. Replaced spark plugs then tried to start it, no start. It's just grinding the starter. It doesn't seem to be getting spark. Any help?
Old Aug 31, 2008 | 01:40 PM
Acidcrakker's Avatar
Default Re: H23vtec won't crank (dashocker)
Your timing is either off or you have no compression.
Old Aug 31, 2008 | 01:42 PM
dashocker's Avatar
What can i do to fix the timing? All that is, is turning the distributer?
If I'm getting no compression what can i do to help with that?
Old Aug 31, 2008 | 01:49 PM
Default Re: (dashocker)
well if you are getting both fuel and spark and nothing is happening its either or.
If its a simple timing is off a new timing belt and tensinor should do the trick.
But if its comp, well thats not good.
Id check comp first if I was you. Go to pepboys or auto zone and get a 40 dollar compression tester.
Test it and when you get the results you will have the awnser.
No comp means pos rebuild, head work. Depends.
Having Compression means timing is off
Where did you get this H23vtec motor in a civic from? Did you build it?
Old Aug 31, 2008 | 01:53 PM
dashocker's Avatar
Yeah it was built and the head and block were redone. I had it bored (stupid machine shop) micropolished and balanced. The head was from my h22 and it was cleaned and polished. I hope its not compression. It was burning oil before this, but it wasn't really bad.
Old Sep 1, 2008 | 09:33 AM
98vtec's Avatar
moderator emeritus
http://www.collectiveracing.net
take your car to scott
Old Sep 1, 2008 | 01:37 PM
dashocker's Avatar
it's being towed down to SRD in tempe, because that is a lot closer to where i live and i have been talking to them and dealing with them since i moved out here.
I will keep collective racing in mind in cause S
RD cannot figure it out.
Old Sep 1, 2008 | 03:26 PM
Speedra500's Avatar
I would agree that the timing might be off
Hondaguy83
Dec 5, 2012 05:21 PM
D16SiHatch
14
Mar 9, 2012 04:17 PM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
SimplyTron
Feb 19, 2007 12:08 PM
g2turbo
Sep 17, 2003 08:31 PM
