Fresh New Motor Has Hard Time Cranking??
Old Aug 31, 2008 | 10:35 AM
tshuajzoo559's Avatar
Default Fresh New Motor Has Hard Time Cranking??
I was told my bearing was too tight...?? Can that be a reason why my motor has a hard time cranking up?
Old Aug 31, 2008 | 10:40 AM
NotNew's Avatar
Default Re: Fresh New Motor Has Hard Time Cranking?? (tshuajzoo559)
Timing being too far advanced can cause hard cranking, or poor battery connections. Bearing clearances shouldnt do that unless somebody doesnt know how to measure before the engine is assembled, which you would have noticed when spinning the crank during assembly. Would have to be super tight to make it hard to start, and I don't think youd want it to start if its that tight.. can you try turning it over by hand with a breaker bar or something just to see? With the spark plugs out it should be fairly easy to turn by hand using the crank pulley bolt and a ratchet or breaker.. also I guess if it was really high compression that could be it..
Old Aug 31, 2008 | 12:20 PM
vtecb18c's Avatar
Default Re: Fresh New Motor Has Hard Time Cranking?? (NotNew)
Timing belt may be to tight
Old Sep 3, 2008 | 07:15 PM
thanks guys....let try and fix it...keep ya updated
zx92027xz
Sep 10, 2015 11:31 AM
Element3488
Oct 3, 2012 08:58 AM
Jimster480
Nov 28, 2010 08:34 PM
Scheizty
Jun 7, 2009 05:09 PM
gangstacritta
Jul 18, 2007 02:55 PM
