auto tranny differences
i have a 95 civic coupe ex and im currently replacing my tranny. I have an auto tranny from a 92-95 civic hatch dx. The tranny from the dx has other sensors on it that the ex tranny doesnt. Would those other sensors matter if i were to install the dx tranny into my car? if it matters these are the tranny codes
dx-A4RA
ex-A24A
dx-A4RA
ex-A24A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onekoop »</TD></TR><TR><TD CLASS="quote">i have a 95 civic coupe ex and im currently replacing my tranny. I have an auto tranny from a 92-95 civic hatch dx. The tranny from the dx has other sensors on it that the ex tranny doesnt. Would those other sensors matter if i were to install the dx tranny into my car? if it matters these are the tranny codes
dx-A4RA
ex-A24A</TD></TR></TABLE>
the A4RA is from a '96 - '00, and yes those extra sensors matter, and no you can't use that tranny. The A24A is a '95 only transmission, '92 - '94 civics used the M24A, this should work fine as far as I can see.
dx-A4RA
oh damn i didnt know
thanks alot man
would you happen to know the other codes of trannys i could use?
like a dx or anything if it would work?
thanks alot man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onekoop »</TD></TR><TR><TD CLASS="quote">oh damn i didnt know
thanks alot man
like a dx or anything if it would work?</TD></TR></TABLE>
An M24A should so far as I can see should work fine, these can be sourced from any automatic equipped civic or del sol from '92 - '94. As far as the automatic transmissions go there is no difference between the DX, LX and EX automatic transmissions, unlike the manual versions they have the same gear ratios and final drive. Your other choice is the A24A, you can find these in any automatic equipped '95 civic or del sol. again it doesn't matter what trim level it came from, there is no difference between them.
thanks alot man
DeathByBoost
Aug 13, 2006 07:53 PM
