Timming belt broke Help!!
Old Aug 30, 2008 | 11:32 AM
ReactioN's Avatar
* B A N N E D *
Default Timming belt broke Help!!
ok so last night my timming belt broke and we got it to the house by pushing it.
so what should do to fix the timming belt?
What do i buy and if you guys have a thing online on how to install it properly please let me know.
First timming bet change today
bTW i have a B18A1 90 Spec
Old Aug 30, 2008 | 12:19 PM
jwrape's Avatar
Default Re: Timming belt broke Help!! (ReactioN)
Well, I'mgonnaassume that you have some bent valves and you will either need a new head or rebuild yours.
This will include all new head gasket, and intake gaskets to replace the head and a timing belt and water pump while your there.
Have fun.
Old Aug 30, 2008 | 12:27 PM
ReactioN's Avatar
* B A N N E D *
Default Re: Timming belt broke Help!! (jwrape)
so shou;d i just not waste money on the timming belt and get new head or what?
Old Aug 30, 2008 | 12:29 PM
boarderwayne's Avatar
even if you get a new head, you still have to put a new timing belt on and a water pump since your in there anyway.
If the belt broke with the engine running you probably did some damage, like JWRAPE said you probably have some bent valves. So good luck, if your down for head work go for it, otherwise pick up a b16
Old Aug 30, 2008 | 12:37 PM
jwrape's Avatar
Default Re: Timming belt broke Help!! (boarderwayne)
Yea, new head, water pump, timing belt and all the trimmings to go with it. Gaskets, etc... Sucks but these motors are such close tolerences now days, there is no room inside the cylinder to fit the valves when the piston is at TDC. My friend Saab did the same thing and his belt didn't break but skip a few teeth. Bent all the intake valves. Talk about expensive valves, they are $80 each valve.
Old Aug 30, 2008 | 12:39 PM
ReactioN's Avatar
* B A N N E D *
i guess my eg is going back to SOHC lol
Old Aug 30, 2008 | 08:31 PM
roberts88's Avatar
jus bring it by the shop. pull the head and get it checked. cheap way to find out if anything is wrong.
Old Aug 30, 2008 | 08:34 PM
ReactioN's Avatar
* B A N N E D *
Default Re: (roberts88)
nah it wasnt pulling anyways so ima go d16y8 or d15b vtec
Old Aug 30, 2008 | 08:38 PM
96lsvtec-t's Avatar
i have no clue why you would just "assume" that the head is trashed......?? something might have happened, and might not. just get a new timing belt, time the motor, and go from there. if it works it works, if it doesnt, then it doesnt. better to find out it doesnt work by trying then to find out it was fine after spending a grip of cash on a different motor.
Old Aug 30, 2008 | 08:46 PM
roberts88's Avatar
yeah try it and if it doesnt. jus go ls vtec. haha you will be happy.
Old Aug 30, 2008 | 08:50 PM
racebum's Avatar
put the timing belt on and do a compression test. that will tell you how far that this project really needs to go.
lilskud13
14
Mar 26, 2009 01:28 PM
GsDAteg
May 31, 2006 06:09 AM
web road runner
Jan 30, 2005 03:52 PM
1hotintegra
Jun 16, 2003 03:10 PM
JSPECEX
11
Mar 28, 2003 07:59 AM
