Car Won't Start...electrical problem...
when i turn the key to the first position all the instrument lights and dome light are koo but when i try to start the car all the lights dim and the car will not start...i seems like its not getting power..and when i turn it to the on position i could hear electrical surging in/or around the fuse panel ...i havent touched or done anything that could of messed it up...and the only way my car will start is with a jump start.. any input on what it might be????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dalejrfan88 »</TD></TR><TR><TD CLASS="quote">Are you sure that your battery is good? I would have that tested first. </TD></TR></TABLE>
X2.
X2.
re-charged my battery...still the same problem... checked the fused that would relate to the the ignition and all that and everything checked out... starting to think it might be a relay but not sure which 1 tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oreo-TeCk »</TD></TR><TR><TD CLASS="quote">re-charged my battery...still the same problem... checked the fused that would relate to the the ignition and all that and everything checked out... starting to think it might be a relay but not sure which 1 tho</TD></TR></TABLE>
re-charge battery does not mean anything, if battery is bad (dead cells).
natek24
Sep 12, 2008 07:28 PM
