knocking noise
ok..92 prelude...just changed the power steering belt and a ticking noise started. It only happens at idle at first start until engine warms up. what could it be? i looked to see if anything was loose or hanging and nothing. any suggestions?
the belt deflection on these belts has to be pretty tight, alot more so than normal application. try tightening belt if you see best fit. are you sure it is sitting on pulley properly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superflow »</TD></TR><TR><TD CLASS="quote">your oil pressure could be low, other than that, check ur bearings and see if anything is wrong with them.</TD></TR></TABLE>
what, are you on the same thread dude? explain bearings, pretty broad statement. anyways......
