B18c1 bracket drivers side question in a 95 ex coupe
Hey I have an odd question probably cause I wanna save money but I have a 1996 b18c1 going into a 1995 civic ex coupe and I got some nice aftermarket mounts for the swap...now the problem is they are for a two bolt driver side set up and I had an idea to maybe switch the Driversdie bracket off a 1993 Acura integra LS since it mounts right up to the B18C1 block but..I am not sure if it will mount up to the chassis with the engine in anybody got anything????
Hey that ended up being wrong but thanks anyways it had to be for a b16 engine and the 1993 LS comes with the B18block I found it just in case you were wondering
its all actually right here couldnt find it before
https://honda-tech.com/zero...12938
its all actually right here couldnt find it before https://honda-tech.com/zero...12938
Raelg14
Honda Civic (2006 - 2015)
Aug 27, 2015 10:06 AM
