ignition timing issue????
ok so i just put an ls trans in m 92 gsr, its now having an idling issues, meaning.... that after it starts it seems like it has no power, so i have to go WOT to get it out of a bog, under 3k it has no power, sometimes when it starts it barely idles, like about 200rpm, seems like the car wants to die but something wont let it, and sometimes the car idles t about 900, wich is were i have it set
now when you replace the trans there are a couple bolts bellow the dizzy, and i know the wrench i was using brushed against the wires on every turn of the wrench, is it possible that i could have knocked the car out of time? if so which way do i need to turn the dizzy to correct it
also once you get the car above 2.5k it feels fine, but once it drops below there is NO go
i have to slip the clutch out at 3k and at this rate ill need a new clutch in a month!!!!
h-duced
Mar 12, 2009 01:45 PM
aquabob89
Apr 25, 2006 10:02 AM
