FUEL AND CLUTCH KILLSWITCH
Old Aug 29, 2008 | 05:49 PM
93DA9's Avatar
Default FUEL AND CLUTCH KILLSWITCH
like the topic says.. i need to know what i need to install a fuel and clutch kill switch..
i know i need toggle switches but i dont know how many amp toggle switches i need..
Old Aug 29, 2008 | 10:35 PM
Davus's Avatar
Default Re: FUEL AND CLUTCH KILLSWITCH (93DA9)
inb4fcm
Depends on where you kill fuel. If it's under the seat, a 15 amp fuse would be best, and as short as possible. You could also put a relay in that area, and control it with a low-amperage switch, but that's a bit more complicated (but not hard by any means).
You could also kill off the main relay, which shuts down various engine sensors, the fuel pump, the injectors, basically guaranteeing the car will not run. This can be done by killing the ground wire, you'll need a 1 amp (less will be very fine) switch for this.
Clutch kill will require very low amperage as well. Any switch you buy at Walmart or an auto parts/boating store will be fine. Whether you use a momentary switch ('horn' style) is up to you. That way you just hold the button, start the car, and continue on as usual. Should be easy to hide.
By your name you have a 1993 Integra - I believe the main relay is in the driver kick area, but unsure.
Old Aug 30, 2008 | 09:42 AM
fcm's Avatar
fcm
Old Fart
Ditto all the above.^^^
Although I will add a momentary switch, N/O, [normally open] will work on the CIS, [clutch interlock switch] a SPST, [on/off] switch is needed for the fuel or PGM-FI Main Relay "kill switch".
If your car is a G2 the PGM-FI Main Relay is to the left of the steering column, more on that if you need it. 94
Old Aug 30, 2008 | 01:03 PM
93DA9's Avatar
Default Re: FUEL AND CLUTCH KILLSWITCH (Davus)
how do relays work?
im new to this i was juss gonna run it straight to the wires w/o a relay
Old Aug 30, 2008 | 05:38 PM
vargas's Avatar
^thats how i did mine,, i think u need a relay when ur switch is more than three feet away from where u tapped the wire
Old Aug 31, 2008 | 05:42 AM
fcm's Avatar
fcm
Old Fart
http://www.the12volt.com/relays/relays.asp 94
Old Aug 31, 2008 | 07:17 PM
paton5g's Avatar
Default Re: FUEL AND CLUTCH KILLSWITCH (fcm)
I installed a kill switch in my 93 Civic which I thought worked really well. My car didn't come with cruise control, so I replaced the blank in my dash with a cruise on/off switch that I bought from Honda. I then wired it into my fuel pump relay. Whenever I parked, I turned off cruise and that was it.
No thief would ever think to push that button. Even if he was smart enough to realize it didn't come with cruise. And it was clean. No hidden switches, wiring was all behind the dash. Easy.
John 07
Nov 10, 2008 05:30 AM
Mr.Death
Audio / Security / Video
Jul 21, 2008 07:11 PM
socalrex88
Mar 2, 2008 01:50 PM
GR_DC2
May 27, 2004 10:51 PM
TypeRod
Sep 7, 2003 07:20 PM
