integra sway bars in ek? & how to install bushing for shift linkage
Old Aug 29, 2008 | 05:25 PM
hondaman_csu_slo's Avatar
Default integra sway bars in ek? & how to install bushing for shift linkage
I have two questions.
1. Does the integra sway bars fit the Ek? I'm looking for some sway bars but can't find any 99-00 civic si sway bars. Only integra sway bars can be found. Just wondering if they fit?
2. How do I put the new energy suspension onto by shift linkage without going to the shop? I don't have a press. What else can I use?
thankz
Old Aug 29, 2008 | 05:35 PM
geebs's Avatar
Default Re: integra sway bars in ek? & how to install bushing for shift linkage (hondaman_csu_slo)
1) not sure of.. i have a gsr rear sway bar i want to put on my ek.. havent gotten around to it yet.
2) the shift linkage bushing arent pressed in. they should pop right out.. actually i think they're two pieces iirc..
Old Aug 29, 2008 | 08:01 PM
Default Re: integra sway bars in ek? & how to install bushing for shift linkage (geebs)
Please let me know when you install your sway bar. I would like to know if they fit as good as the 99-00 civic si's sway bars.
As for the bushing, the energy suspension does not come in two piece (the one that I ordered). It is for a b16 though. I saw on youtube that some of the bushing for the lower control arms were pressed into their place. I was just wondering if they were the same. I tried using my palms but i was no way near getting it in.
Old Aug 29, 2008 | 08:06 PM
dangthemang's Avatar
aren't ITR and CTR sway bars the same thing? i don't see why a gsr sway wouldn't fit into an ek.
Old Aug 29, 2008 | 10:42 PM
turnsignalandy's Avatar
Default Re: integra sway bars in ek? & how to install bushing for shift linkage (dangthemang)
depending on the exhaust setup the GSR swaybar may or may not fit. It has a different shape then a SI rear swaybar.
Old Aug 30, 2008 | 01:56 AM
cmgibby's Avatar
i've read & been told that a GSR fits a EK, i have thought of buying on off HT-market place. there are some threads out there about it, "serach" or ill try to find it
the ES bushings for shift linkage DO NOT need a press to fit in, or so mine did not. although i have a D16 motor & D series tranny
Old Aug 30, 2008 | 01:59 AM
cmgibby's Avatar
this is 1 of several threads that speak of your answer
https://honda-tech.com/zerothread?id=1811253
3K_Hatch
Dec 17, 2017 12:31 PM
jrunager
Suspension & Brakes
23
Oct 24, 2012 10:30 AM
lil danny
12
Apr 4, 2009 08:18 PM
Midori Green
Aug 21, 2008 06:36 PM
beav
Suspension & Brakes
13
May 31, 2005 07:24 PM
