obd0 b16a no spark
Old Aug 29, 2008 | 04:16 PM
jeremiah963's Avatar
Default obd0 b16a no spark
so i was driving last night and my car just died on me..... it was driving fine but then is lost all power and back fired!!!!! today i checked the dizzy cap and rotor to find that the rotor was in peaces inside the dizzy cap so i replaced that.... still nothing.... changed the whole dizzy with a known working dizzy nothing.... checked timing at the cam gears and they look to be right.. all grounds are good... pulled the spark plugs out and they were black so i know its getting fuel... also i can smell fuel... ive tryed switching out to a stock pr3 ECU and still no spark... i have also changed out the main relay..any other ideas.... please let me know this is my DD
Old Aug 30, 2008 | 05:47 AM
Default Re: obd0 b16a no spark (jeremiah963)
morning bump
Old Aug 30, 2008 | 08:36 AM
jetrules's Avatar
1. check all the fuses and relay that control the ignition.
2. check the timing belt teech are ok.
3. check to see any pwr goes thru to dizzy.
4. check the ignitor and ignition coil are ok.
Old Aug 31, 2008 | 02:27 PM
Default Re: (jetrules)
switched out spark plugs today and still no spark.... im getting power to the dizzy.... gettin power to the coil but theres no power coming out... put in a new coil and ignitor.... still no spark... so i got curious and took my old dizzy apart to find that it is locked up and will not turn at all...... i started checking cam to crank timing to find that its about 2 -3 teath off... so i am going to put it back in time and hope for the best..
Old Sep 1, 2008 | 04:30 PM
Default Re: (jeremiah963)
put it back in time still no spark
Old Sep 2, 2008 | 11:29 AM
ttt
jeremiah963
10
Sep 2, 2008 03:38 PM
tyler100
Aug 24, 2008 06:28 AM
GrnZ
Mar 30, 2008 07:16 AM
mini-meEj1
16
Jan 1, 2008 10:14 AM
91' LS-VTEC
Apr 5, 2006 12:06 PM
