accord ex injectors into a b16?
Old Aug 29, 2008 | 02:57 PM
jdmdikk's Avatar
Default accord ex injectors into a b16?
i was told by a friend of mines to place 94+accord ex injectors into my 00 b16 motor..he said that i will have increased power..is this true,or has anyone done this before??
Old Aug 29, 2008 | 03:29 PM
unsungfate's Avatar
Default Re: accord ex injectors into a b16? (jdmdikk)
do you have a fuel regulator? are you putting more pressure through your fuel line? and, are the accord injectors bigger (higher flow) than the SI's? (which i doubt) unless you upgrade your fuel delivery then higher flow injectors (any) won't do a thing... if you want higher flow injectors that are not all crazy or expensive... you should get gsr or type-r injectors.
Old Aug 30, 2008 | 05:26 AM
jdmdikk's Avatar
Default Re: accord ex injectors into a b16? (unsungfate)
i was told that it has way better flow and that i would need it with the injector plugs..i do plan on putting a fuel pressure regulator for more gas flow
Old Aug 30, 2008 | 05:30 AM
THC07's Avatar
is your motor stock?
Prelude injectors are best imo, i dont know what cc the accourd injects are.
1992-96 Prelude VTEC peak n holds
1997-up Prelude VTEC saturated
why do you want more fuel?
Integra99
May 31, 2005 05:25 PM
jdmb1697ek
15
Apr 11, 2005 08:03 AM
dazn
Mar 2, 2004 10:17 AM
H23 Power
Feb 25, 2002 02:56 PM
PyroVTEC
Dec 9, 2001 10:35 PM
