how do i clean the milk shake out of a good head and block.
Old Aug 29, 2008 | 02:42 PM
915hondajunkee's Avatar
Default how do i clean the milk shake out of a good head and block.
I blew the head gasket on my 91 hatch it. has been put back together. after putting new oil and filter. i ran the hatch it sounds good but inspecting the oil there is some milkshake and the oil got contaminated.. how is the best way to flush of the residue left behind and how many more oil changes to clean this motor.....help pleasee im dying to drive my hatch! ! !
Old Aug 29, 2008 | 02:57 PM
Maxcapacity's Avatar
Default Re: how do i clean the milk shake out of a good head and block. (915hondajunkee)
In auto parts stores they have engine flush, $5.. add it to the oil, run it for 5min, then drain and flush it with about half as liter.. If you still have milky oil after driving with the fresh oil change your back to square one..
Old Aug 29, 2008 | 03:09 PM
Default Re: how do i clean the milk shake out of a good head and block. (Maxcapacity)
Thanx for the info...im on my 1st flush. and prepared to do about two..if the my budget permits.. what i want to know is if eventually all the milkshake will be gone...maybe two more flushes will do it...
Old Aug 29, 2008 | 04:36 PM
what about using gasoline??????????????
Old Aug 29, 2008 | 05:36 PM
HiProfile's Avatar
Gasoline is a bad idea. It will avoid the water (milkshake), but disolve into the oil - acting like a degreaser. Then you could potentially have a metal-metal contact between some bearings, and the 1st few seconds you crank the motor - they'll be toast.
Just flush it now, and again a couple dozen miles later if still present. As long as its not too much, it will remain as a residue on certain surfaces and at the bottom of the pan. Only a few auto-x'ing laps would agitate it enough to get sucked up.
Old Aug 29, 2008 | 10:40 PM
TOO MUCH TORQUE's Avatar
amsoil engine flush!
Old Aug 30, 2008 | 01:00 AM
bobjohnson's Avatar
Buy some cheap oil at the same time you run the engine flush stuff (Like really, really cheap oil, the cheapest they have). Run the engine flush stuff, and then after you drain the oil, pour a big jug of the cheap oil slowly through the engine and wait for it to drain out of the bottom. You should be good to go after that.
Old Aug 30, 2008 | 08:19 AM
acmoc's Avatar
Default Re: how do i clean the milk shake out of a good head and block. (bobjohnson)
I heard tyhat at the dealerships they use transmission oil
Old Aug 30, 2008 | 04:05 PM
redef90si's Avatar
Default Re: how do i clean the milk shake out of a good head and block. (acmoc)
seafoam or engine flush
Old Aug 30, 2008 | 04:27 PM
crxjarred's Avatar
Default water
cant u just flush with a water hose??
like dont start it up just use the presure of the pushing water to push all of it out??
Old Aug 30, 2008 | 04:33 PM
Default Re: how do i clean the milk shake out of a good head and block. (redef90si)
fIRST OF ALL THANK YOU ALL FOR YOUR FEEDBACK!! I MEAN IT ITS GOOD TO KNOW THAT HONDA HEADS STICK TOGETHER... NOW WHAT I ENDED UP DOIN WAS RUNNING HALF A QUART OF TRANNY FLUID WITH 3.5 OF OIL... RAN FOR TEN MINUTES THEN DRAIN. THE USED 3.5 OIL AGAN AND AND ENGINE FLUSH... THE DRAIN THEN 3.5 QUARTS MORE OIL AND .5 TRANNY RAN TEN MINUTES THEN DRAIN.. FILL BACK UP WITH FRESH OIL AND NEW FILTER..... thank god the milkshake is gone!!!!!!!!!thaank you all who replied... and special thanx to powered by del motorsports in el paso texas........915.......
jnb0111
Oct 25, 2015 04:13 PM
Dat1BVtecN
Mar 17, 2007 09:17 PM
92redhatch
Aug 27, 2006 09:52 AM
Si Shane
Sep 18, 2005 10:14 PM
synergy004
Jul 28, 2002 09:12 AM
