need help with piston question
ok i am looking at rebuilding my engine this winter and found a kit with a the itr pistions...will i have to bore my jdm b18c sir-g block or will these pistons be a swap and go?
If you're rebuilding your block you should be overboring the cylinders. Make sure your new pistons are 81.5mm and have your cylinders bored to match.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">If you're rebuilding your block you should be overboring the cylinders. Make sure your new pistons are 81.5mm and have your cylinders bored to match.</TD></TR></TABLE>
If you are feelin' ballsy go to 82mm.
Chief Wenceslaw
Apr 14, 2006 07:07 PM
crx1856
Nov 3, 2003 05:10 AM
