Civic not turning over?
Old Aug 29, 2008 | 11:57 AM
kuks24's Avatar
Default Civic not turning over?
I have a 97 civic. I started the car and it ran for two seconds and shut off. Now when I try to start it, the belts just spin. It sounds like a distributor cap problem or spark problem. ANy suggestions. The starter just spins and that is it. THanks. It doesn't even try to turn over.
Old Aug 29, 2008 | 11:59 AM
-Gambit-'s Avatar
Default Re: Civic not turning over? (kuks24)
is your fuel pump priming, are you getting spark?
Old Aug 29, 2008 | 12:00 PM
kuks24's Avatar
Default Re: Civic not turning over? (-Gambit-)
How do I check spark and the fuel pump?
Old Aug 29, 2008 | 12:26 PM
blk92_d16's Avatar
To check spark (very easy with two people), remove the spark plug from the head but had it still connected to the plug wire. Arc or ground the plug off the valve cover to reveal "the spark".
For the pump, turn the key to the ON position and you should hear the pump prime for like 3-4 seconds. If you don't hear this, it just might be the main relay.
philztheone
Nov 5, 2014 10:28 AM
jonina
20
Oct 8, 2011 09:57 AM
94hatchy
21
Nov 13, 2010 05:23 PM
DelSlowmo
61
Feb 12, 2009 07:50 PM
blueR87
Aug 5, 2005 01:10 AM
