HELP!!!!
Old Aug 28, 2008 | 05:57 PM
gbg2w1's Avatar
Default HELP!!!!
I just hooked up a apexi turbo timer everything is wired just like on the diagram
.red- con. 12v(fat white)
.blue -Acc (yellow)
.green- ing 1 (blk/ylw)
.black- ground
now it turns on reads bat correct and time fine. The problem is when i turn the car off it runs for the time as its suppose to BUT at the end of the time it starts over. the car turns off just for a milisec then turns back on and the time starts over. Sometimes it will turn off after about three cycles but other times just runs...... now this thing turns off 50/50
Old Aug 28, 2008 | 06:28 PM
onefastek9's Avatar
wire the parking brake
Old Aug 29, 2008 | 12:04 PM
gbg2w1's Avatar
Default Re: (onefastek9)
done
Old Aug 29, 2008 | 01:03 PM
onefastek9's Avatar
Default Re: (gbg2w1)
DONE???? you mean it's wired? or fixed
Old Aug 30, 2008 | 05:45 PM
gbg2w1's Avatar
the parking brake is wired.. thats how i turn it off when it wont turn off. it now has changed to never working. the thing counts down but just restarts. i also need to know how to wire it so it will work with my alarm
Old Aug 30, 2008 | 07:39 PM
onefastek9's Avatar
sounds like your wiring the timing on full power, meaning the wires are not splic between the plug harness and the ignition, it's just taped into the ignition. that's why it wont shut off your car and just restarting it right after its done counting down, do you have a plug and play harness? or is it hotwired in?
Old Oct 5, 2008 | 06:06 PM
gbg2w1's Avatar
sorry its been a wreck with my ride blew radiator cause of oh. the timer is wired in str8 from the ign. should this be wired somewhere else or further down??
nanaprelude
Mar 27, 2018 10:52 AM
crappyshifting
May 13, 2012 04:27 AM
crxzcracer
Mar 19, 2005 02:39 PM
crxzcracer
Mar 19, 2005 02:03 PM
B18EG6
Aug 17, 2002 03:53 PM
