need help
i went to change my timing belt on my 98 civic ex 5 speed but couldnt rmove pulley so i put everything back together went to go start it and it will turn over but will only idle if the throttle is wide open and runs really rough i think the cfk wire grounded since it was squished so i moved it but it still wont start Help!!
sounds to me like like your cam gears moved a tooth and your timing is out of wack.
did you mark them top and bottom or draw a line across so they will mate back up in the right spot???
Lao17
12
Aug 2, 2011 01:49 PM
h46it
May 17, 2003 08:26 PM
PatrickGSR94
Apr 11, 2003 04:21 PM
