Could you me calculate my setup?
Old Aug 28, 2008 | 02:28 AM
4drteg54321's Avatar
Default Could you me calculate my setup?
I want to know my compression.
Stock Gsr head
Oem HG
Ls block, crank, rod
type r piston usdm
Old Aug 28, 2008 | 03:41 AM
IntegraType-R's Avatar
Default Re: Could you me calculate my setup? (4drteg54321)
11.95 if ur only reving to 8000 and have the head/block just resurfaced.
Old Aug 28, 2008 | 03:49 AM
vinuneuro's Avatar
Default Re: Could you me calculate my setup? (IntegraType-R)
http://www.zealautowerks.com/index.html
Old Aug 28, 2008 | 11:24 AM
Are those good compression to bring out the power in sk2 stg2 cams??
Old Aug 28, 2008 | 11:37 AM
91whiteZCrex's Avatar
Default Re: (4drteg54321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drteg54321 &raquo;</TD></TR><TR><TD CLASS="quote">Are those good compression to bring out the power in sk2 stg2 cams??</TD></TR></TABLE>
yes s2s2 should be good. pro1 better
Old Aug 28, 2008 | 12:06 PM
Default Re: (91whiteZCrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91whiteZCrex &raquo;</TD></TR><TR><TD CLASS="quote">
yes s2s2 should be good. pro1 better </TD></TR></TABLE>
s2s2's have a bigger vtec lobe.. primaries on the pro1's are the only things bigger.. and bigger is not always better..
Old Aug 28, 2008 | 12:21 PM
Default Re: (IntegraType-R)
f<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">
s2s2's have a bigger vtec lobe.. primaries on the pro1's are the only things bigger.. and bigger is not always better..</TD></TR></TABLE>
That's not what she said
Old Aug 28, 2008 | 03:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91whiteZCrex &raquo;</TD></TR><TR><TD CLASS="quote">f
lmao +1 for you sir.
Old Aug 28, 2008 | 03:49 PM
DonF's Avatar
What are the actual head cc's, the block cc's with pistons @ tdc, and head gasket. Then you can tell, other than that, the experts are guessing, as most have never really figured it out, just hoped the internet was right.
Old Aug 28, 2008 | 03:50 PM
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">What are the actual head cc's, the block cc's with pistons @ tdc, and head gasket. Then you can tell, other than that, the experts are guessing, as most have never really figured it out, just hoped the internet was right.</TD></TR></TABLE>
lol you love drilling people, dont you.
Old Aug 28, 2008 | 04:04 PM
DonF's Avatar
lol you love drilling people, dont you.</TD></TR></TABLE> Well am I right or wrong? Are all GSR heads the same? Are alldeck heights the same? He has Approx. 11.4-12, I guess.
Old Aug 28, 2008 | 04:08 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> Are all GSR heads the same? Are alldeck heights the same?</TD></TR></TABLE>
From the factory, they are pretty close.
Old Aug 28, 2008 | 04:16 PM
DonF's Avatar
Default Re: (mar778c)
I need a cc burete then. Oh, wait we did a valve job, changed valves, and a surface. Yup, checked Zeal, theys be correct. Good thing I did not surface the block or change rods or pistons, as they are allways the same to the cc.
Old Aug 28, 2008 | 04:24 PM
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">I need a cc burete then. Oh, wait we did a valve job, changed valves, and a surface. Yup, checked Zeal, theys be correct. Good thing I did not surface the block or change rods or pistons, as they are allways the same to the cc.</TD></TR></TABLE>
i'm not saying your not correct..
i'm just joking with you lol i know your right.
Old Aug 28, 2008 | 04:33 PM
DonF's Avatar
i'm just joking with you lol i know your right.</TD></TR></TABLE> I ment to sat "new" burete. The problem is I have seen the " internet" numbers go 1 point high or low. They are a good starting point, just not "that" accurate.
Old Aug 29, 2008 | 11:04 AM
Rocket's Avatar
Default Re: (DonF)
I "cc" without a burette.
Think a lil and you might come up with it.
*********** need not try....you know who you are.
Precision Tools fo da win!!!
Old Aug 29, 2008 | 11:56 AM
DonF's Avatar
Default Re: (Master of the Universe)
It was just a rumor.
ge_itr
Sep 4, 2007 12:09 PM
Del Sol on Steroids
May 27, 2007 03:34 PM
I makes it RAIN
19
May 6, 2006 07:38 AM
slayersluck
18
Jan 25, 2006 12:24 PM
crooked muffler
Sep 4, 2004 02:17 PM
