ls/vtec compression
Old May 26, 2007 | 05:44 PM
Del Sol on Steroids's Avatar
Default ls/vtec compression
does anyone know what the compression ratio is for a LS setup with a gsr head. Or does anyone know what compression do get on piston to bring it to 12:1?
Old May 26, 2007 | 06:39 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ls/vtec compression (Del Sol on Steroids)
http://www.c-speedracing.com/h...c.php
Old May 26, 2007 | 07:35 PM
Dartanian's Avatar
Default Re: ls/vtec compression (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
http://www.zealautowerks.com/ is more accurate.
Old May 27, 2007 | 05:31 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ls/vtec compression (Dartanian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.zealautowerks.com/ is more accurate.</TD></TR></TABLE>
I do like how that site breaks down the variables and allows for boost.
Old May 27, 2007 | 08:03 AM
Sam92Teg's Avatar
Just so you know, if your using stock LS rods and want a stock piston, alot of people choose the P30 piston which requires no modification to fit the stock LS rods and will give you around 11.5-1 compression. PR3 pistons is another option and would result in .2 less compression.
Old May 27, 2007 | 01:04 PM
Default Re: ls/vtec compression (Sam92Teg)
yea, i thought of p30 with high compression valves, to get 12:1, but i rather save that money.
Old May 27, 2007 | 01:09 PM
doood's Avatar
been there done that
why do you need so much compression? what cams will you be running?
Old May 27, 2007 | 01:41 PM
numbnuts22715's Avatar
Default Re: ls/vtec compression (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">why do you need so much compression? what cams will you be running?</TD></TR></TABLE>
high compression most likely for all motor
Old May 27, 2007 | 03:33 PM
pro1's
Old May 27, 2007 | 03:34 PM
already got the spring kit
valiente540
Feb 2, 2008 11:38 PM
zerogravitycrx
10
Nov 22, 2006 01:13 PM
Dent Free
Nov 23, 2004 10:23 PM
b18coupe
Mar 10, 2004 04:33 AM
beaterman
Aug 29, 2003 12:07 AM
