injector wont fire after 0bd1 conversion
Old Aug 27, 2008 | 06:20 PM
2poor2tune's Avatar
Default injector wont fire after 0bd1 conversion
ok so a 88 civic dx, i have wired to mpfi, 0bd1,vtec all at once and im not getting anything from the injectors. replaced the resistor box with obd 1 plug and need help
Old Aug 27, 2008 | 08:12 PM
kmartcivic's Avatar
Default Re: injector wont fire after 0bd1 conversion (2poor2tune)
I had the same problem with my obd2 b16 in 89 crx. Or thats what I thought cause it wouldnt start, but if I sprayed some starting fluid in the t/b it would run rough for a couple seconds. turned out it was the dizzy wired up wrong. Fixed that and it fired right up.
Old Aug 27, 2008 | 08:30 PM
crxfreak1117's Avatar
Default Re: injector wont fire after 0bd1 conversion (kmartcivic)
so are you using obd0 or obd1 injectors?
Old Aug 28, 2008 | 01:32 AM
2poor2tune's Avatar
Default Re: injector wont fire after 0bd1 conversion (crxfreak1117)
Sorry I diddent get enough information I was in a rush to leave my house.
Ok here's the deal I have tested all wires and all chacked out fine as far as the dizzy wich I wired 4 different ways. All the obd1 injectors get the pulse of power needed to fire them and are connected properly to the fancy obd1 connection plug instead of resistor box. But here is the deal they won't spray out all the way like normal. But it seems like every other time it reciaves siglan the squirt out barely any fuel.(enough to turn the **** over and try to start and make me try for 30 minutes lol) im pretty sure now that I have tripple checked the wiring that the injectors are bad. Ill swap them tomorrow and update this thread. Its a d15b btw. Baller clutch and flywheel, going for boost later
surkitroller
Dec 29, 2009 12:58 PM
beansandrice
33
Sep 8, 2009 04:18 PM
bigodub93
Jan 11, 2008 05:30 PM
Gcar
Aug 3, 2004 05:44 AM
JDMCivicEF9
19
Sep 6, 2003 11:00 AM
