D16a6 Vitara H Beam Turbo Engine Swap, Everything but the Tranny! Cheap!
Old Aug 27, 2008 | 04:54 PM
Jwbetley's Avatar
Default D16a6 Vitara H Beam Turbo Engine Swap, Everything but the Tranny! Cheap!
Looking to sell my d16a6 turbo engine. Everything needed to convert a (preferably OBD0) civic to a nice street car. The kit was in a civic wagon. The charge pipes
should fit most civics with minor modifications. The act clutch is compatible with all d16 transmissions and I will include a brand new act throw-out bearing. The engine runs very strong and was professionally built.
Engine:
-Completely rebuilt bottom end ( Eastwoods Machining; Somers, CT) ,less than 8K
-Vitara 75.5mm Pistons
-TT H-Beams Rods
-ARP Head studs
-All new OEM bearings and seals
-Professionally Rebuilt d16a6 head with new valve seals/ Resurfacing
-d16y8 MLS Headgasket
-Resurfaced flywheel and ACT six puck clutch ($$$)
-3in aluminum radiator
Turbo:
-new t3 50 trim turbocharger, 4 bolt flange
-Custom 2.5 mandrel aluminized steel charge pipes, Done by me, Very professional
-2.25 to 2.5 mandrel downpipe also done by me, also very professional looking work
-External ebay wastegate, 35mm with a 1 bar spring
-DSM BOV
-Manual boost controller
-Cast log manifold powder coated with high temperature ceramic coating
-Custom Home-depot pvc catch-can with drain valve.
-Blackout Ebay Boost gauge
-PLX M300 wideband located inside the glove compartment
-Includes oil line and return + t3 restrictor
-ECU tuned on crome from Xenocron. Needs a tune.
- Ebay FMIC 2.5 in/out
-All 4-ply rubber connectors and T clamps, including 2 90 deg elbows
Wheels:
-Rota Slip Stream Style wheels in very decent condition. Only a couple scrathes on the lip. Needs new tires. Tires (blizzacks) now do hold air and are functional, just bald.
- I will include axles, halfshaft, a spare d16a6 block an head, and numerous other randon civic parts.
I am looking for roughly 2500k for everything. I will part out some things upon request. Please let me know if your interested in converting your stock or NA civic into a street monster. I am located near Enfield Connecticut and prefer local pick-up. I may ship the wheels.
Thanks,
-Justin
My email is rexemouse@hotmail.com if that is your prefered form of communication.
Old Aug 29, 2008 | 10:59 AM
Jwbetley's Avatar
Default Re: D16a6 Vitara H Beam Turbo Engine Swap, Everything but the Tranny! Cheap! (Jwbetley)
Buy it
Old Aug 30, 2008 | 06:53 PM
crx(gator)'s Avatar
how much is the enigne?
Old Aug 31, 2008 | 09:07 AM
Jwbetley's Avatar
Default Re: D16a6 Vitara H Beam Turbo Engine Swap, Everything but the Tranny! Cheap! (crx(gator))
Pmd
Old Sep 2, 2008 | 04:40 AM
Jwbetley's Avatar
Still up, offer me something
Old Sep 4, 2008 | 07:27 AM
Jwbetley's Avatar
Make an offer!
Old Sep 6, 2008 | 02:10 PM
Jwbetley's Avatar
Still up
Old Sep 8, 2008 | 08:04 AM
Jwbetley's Avatar
make an offer
funkfnamna
Apr 25, 2013 12:28 PM
sameerb1
Oct 6, 2011 12:55 PM
patrickd_21
196
Feb 18, 2009 11:31 AM
Jwbetley
Nov 8, 2008 07:50 PM
Jay.D.Em!
Mar 18, 2007 02:34 PM
