recommended spark plugs???
Old Aug 27, 2008 | 06:10 AM
00b20vtecoupe's Avatar
Default recommended spark plugs???
Hi, im running a fully built b20 vtec setup with 12.5 cr and im wondering what the best spark plug set up is. When it was built i belive my tuner used standard ngk coppers. Idk if it was b/c the motor runs hotter and copper is better or what but i tried running iridiums 1 time and it ran like ****. Just wondering what people are running in similiar setups and whats recommended... thanks
Old Aug 27, 2008 | 07:23 AM
blacK_Dc4's Avatar
Default Re: recommended spark plugs??? (00b20vtecoupe)
try ngk R5671A-8
Old Aug 27, 2008 | 08:50 AM
98vtec's Avatar
moderator emeritus
Default Re: recommended spark plugs??? (blacK_Dc4)
NGK v-power
1.99 a plug.
Old Aug 27, 2008 | 08:59 AM
Default Re: recommended spark plugs??? (98vtec)
thats wat i have in there now the copper v powers.
Old Sep 21, 2008 | 03:47 PM
jeff652's Avatar
What is the life on these plugs (i.e. mileage)?
Old Sep 21, 2008 | 05:41 PM
tensecpass's Avatar
boush plus 2 is the best by far. they have plus 4 too but i run plus 2s
Old Sep 21, 2008 | 05:49 PM
98vtec's Avatar
moderator emeritus
Default Re: recommended spark plugs??? (tensecpass)
you mean the ones with extra ground straps to block the spark from getting to the fuel?
Old Sep 22, 2008 | 04:11 AM
Furyof4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tensecpass &raquo;</TD></TR><TR><TD CLASS="quote">boush plus 2 is the best by far. they have plus 4 too but i run plus 2s</TD></TR></TABLE>
How did do you determine their "the best by far" ?
Butt dyno im guessing.
Old Sep 22, 2008 | 01:02 PM
all-mtr-teg's Avatar
Have you ever heard of flame kernel?
Old Oct 20, 2008 | 09:05 AM
Default Re: recommended spark plugs??? (all-mtr-teg)
currently running v powers and i believe gapping is about .038 due to recomendation on here. as i hear rec. for high cr would be about .038 for a smaller gap. stock motor reccomends .052. is .038 a good gap for high cr b20 vtec?
Old Oct 20, 2008 | 09:13 AM
1SiC 3DR's Avatar
try bkr7e-11 stock number 6097 alot of people on H-T uses these plugs and i personally use them on alot of nitrous cars and high cr AM cars
Old Oct 20, 2008 | 09:17 AM
Default Re: recommended spark plugs??? (1SiC 3DR)
wat r u gapping the plugs to?
Old Oct 20, 2008 | 09:34 AM
FST GSR 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiC 3DR &raquo;</TD></TR><TR><TD CLASS="quote">try bkr7e-11 stock number 6097 alot of people on H-T uses these plugs and i personally use them on alot of nitrous cars and high cr AM cars</TD></TR></TABLE> Alot of nitrous cars running what jet?
Old Oct 20, 2008 | 01:34 PM
1SiC 3DR's Avatar
Default Re: recommended spark plugs??? (FST GSR 1)
nitrous cars i gap to .32 allmotor cars around .38, and <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FST GSR 1 &raquo;</TD></TR><TR><TD CLASS="quote"> Alot of nitrous cars running what jet?</TD></TR></TABLE> anywhere froma 60 shot to a 125 so far
Old Oct 21, 2008 | 03:50 AM
FST GSR 1's Avatar
There really is no such thing as a "shot" size, thats why I asked what jet. Since your nitrous jet should never change in tuning.
Old Oct 23, 2008 | 06:09 AM
1SiC 3DR's Avatar
Default Re: (FST GSR 1)
most 60 hp kicks are around 038 n20 and 022 fuel dont hold me to it but i think thats right
Old Oct 23, 2008 | 08:28 AM
FST GSR 1's Avatar
Are these single nozzle systems?
Anything over "100" should be more then 1 step colder.
Old Oct 23, 2008 | 02:02 PM
1SiC 3DR's Avatar
yea single fogger nozzles i usually go 7 heat range because most people eventually want more cant blame em really
Old Oct 23, 2008 | 03:10 PM
jdong's Avatar
Default Re: (1SiC 3DR)
i use 7 on mine on 35 gap
Old Oct 24, 2008 | 08:30 AM
2001B18C1GS-R's Avatar
ngk bkre7 without the 11 on the end and i gap to 35 as builder recommends i have 11-1-115 comp dont know exaclty made 191 whp with ac and ps belts on all motor
Old Oct 24, 2008 | 12:47 PM
IntegraType-R's Avatar
Fail.
Old Oct 24, 2008 | 12:56 PM
flesh199's Avatar
Default Re: (2001B18C1GS-R)
br7es with 35 gap 247/175 hp allmotor
FRKWOO
13
Apr 5, 2009 06:49 PM
hondadc2
Aug 7, 2008 11:37 AM
veritasaequatis
14
Feb 6, 2007 03:08 PM
JerkzEm1
14
May 3, 2005 10:05 AM
LSVTEC 91 Civic
May 16, 2004 04:24 PM
