Which axle for crx 2.gen?
Old Aug 27, 2008 | 04:11 AM
Catch's Avatar
Default Which axle for crx 2.gen?
hi
i have a problem and i was wondering is some one could help me;
the problem is this; i did a b16a2 swap into my 1991 crx, and i used a b16a1 tranny; and now i cant figure out which axles should i use; a which are theire dimensions (lenght);
i hope i wrote it the right way and i also hope that some one could help;
P.S.- and also if some knows whats the lenght of the original crx b16 axels;
thank you;
Old Aug 27, 2008 | 06:39 AM
LA_HONDAS's Avatar
Default Re: Which axle for crx 2.gen? (Catch)
90-93 da axles
Old Aug 27, 2008 | 08:00 AM
Catch's Avatar
thats from the integra b18a1 engine?
Old Aug 27, 2008 | 08:13 AM
LA_HONDAS's Avatar
Default Re: (Catch)
yes it is
Old Aug 27, 2008 | 08:19 AM
LA_HONDAS's Avatar
Default Re: (LA_HONDAS)
no they will not be to short its the 89 integra axles you dont want
just get the 90-93 integra axles and youll be good to go
Old Aug 27, 2008 | 08:25 AM
Catch's Avatar
ok, thanks
i was thinking about the crx ef8 axles; but if you say 90-93 integra then ok;
Old Aug 27, 2008 | 08:33 AM
LA_HONDAS's Avatar
Default Re: (Catch)
what kind of front hubs do have
if you have hf hubs you have to change them
Modified by LA_HONDAS at 11:48 AM 8/27/2008
Old Aug 27, 2008 | 08:46 AM
Catch's Avatar
sorry, could you put a pic of the hubs, if you can, because i dont really understand;
i only did an ecu, engine and tranny swap; nothing else; originaly the car was a d16 crx;
Old Aug 27, 2008 | 08:50 AM
LA_HONDAS's Avatar
Default Re: (Catch)
what model crx you have
si hf dx
Old Aug 27, 2008 | 09:00 AM
LA_HONDAS's Avatar
if it came with a d16 then so im gonna say its a si so you good to go with that
the axles will fit in hub then
Catch's Avatar
i really cant tell you 100%
e for the europe market and its and ED model;
i think its similar as the si model (jdm or usdm)
but im not 100% sure
p.s.- thank you for your help!!
2x0
16
Sep 21, 2017 05:13 AM
hondaguy69
Jun 25, 2006 07:38 PM
Grnade
Sep 8, 2004 01:00 PM
joey1320
Dec 17, 2002 04:20 PM
