ignition faults? please help asap!
Old Jul 24, 2002 | 02:33 AM
austrian type-R's Avatar
Default ignition faults? please help asap!
Okay, I drove home from work and reved up to 8800rpm with no problems. Then I took the BFG DRAG radials into my trunck and droved with a friend to a straight street. Then we changed the tires and we wanted to measure the acceleration with Gtech. A little burn out (damn, the BFGs pulled my car about 5 meters while the e-brake was fully on)
Okay, we calibrated the Gtech and I started. But once of a sudden the engine stutters above 7000rpm. In all gears at low boost too. We changed the spark plugs. It was dark already, but we had a flash light. New run, but the same results.
The eninge runs great up to 7000rpm, but then there is something wrong!
Can this be ignition fault? Maybe time for a new distributor or something?
Damn, and this 5 days before a huge DRAG event, I'm scared! Guys plesae help out quick
oh yeah, I have stock ignition, Fuel press was fine too
I run max 1.2 Bar boost for 7500 miles not once of a problem. It happend yesterday suddenly. I use NGK copper plugs heat range 7 with plugs stock gap for also 7500 miles with no problems.
Perhaps the plug wires are defect?
Old Jul 24, 2002 | 02:43 AM
DutchITR1689's Avatar
Default Re: ignition faults? please help asap! (austrian type-R)
The fact that it only happens above 7000 rpm makes me think it's engine knock (pinging).... So, lowering boost didn't help?
How about retarding the ignition timing a bit....
Was it hot that day?
[Modified by DutchITR1689, 12:56 PM 7/24/2002]
Old Jul 24, 2002 | 03:04 AM
Default Re: ignition faults? please help asap! (DutchITR1689)
No, I don't think it is knock, why should it suddenly knock? It was a realy cool night about 20 degrees C. It happens on all boost setting.
I filled up the gas tank with RON 99 (like every time) but same things happen. WTF only 1 day time to order parts from Honda to get em on friday. I hope a spark plug wire and a distributor is stock in Vienna. I have 1 autoX and 1 DRAG event on sunday, won't miss it. Biggest DRAG event in Austria.
Old Jul 24, 2002 | 03:10 AM
Who build your motor? Did you ask him?
Old Jul 24, 2002 | 03:27 AM
yeah, I asked him, he also thinks distributor and/or spark plug wires. Honda distributors are known to be waek. Too bad, that the distributor fom B16A2 or any other Honda engine do not fit. I only know 1 Integra driver in my area to test his distributor on mine, but he has no time until friday....and friday is too late to order a new one from Honda. DAMN, what a mess.
I have to measure the impendance of the wires in 3 hours, than I will know more.
Old Jul 24, 2002 | 03:48 AM
Ex-ITR5874's Avatar
What was the effect of retarding timing 1-2 degrees above 7000rpm ??
Old Jul 24, 2002 | 03:53 AM
Maybe it's time for some good sparks like this MSD ignition?
Old Jul 24, 2002 | 04:00 AM
I don' t have retarded the timing yet, why should I, engine runed always great with my setted ignition and fuel maps. Even on low boost is this problem. It is a rev depend problem and not a boost dependend one.
Stock ignition was always good enough, even on high boost I had no troubles to get enough spark. When the ignition would be that bad, I should not be bale to boost that much like I did the past 4 month.
Old Jul 24, 2002 | 04:03 AM
Ex-ITR5874's Avatar
[QUOTE]why should IQUOTE]
To see what happens.... and to come closer to the problems cause...
Old Jul 24, 2002 | 04:07 AM
Default Re: ignition faults? please help asap! (ITR1858)
hm, maybe, but I realy doubt it.
ralph11sec
Feb 11, 2010 05:04 AM
Boostinb20!
Jul 16, 2009 02:33 PM
nonvteclude
May 23, 2009 06:14 PM
dmecarboy
Mar 25, 2003 10:37 PM
austrian type-R
Jul 24, 2002 07:47 AM
