Honda S2000 Honda S2000
Question about crank vent...
Old Aug 26, 2008 | 07:46 PM
RedstarS2K's Avatar
Default Question about crank vent...
Hi everyone,
I have a problem since i installed the crank vent on my 2001. Everytime after a good spirited ride I pop my hood and my dip stick is shot out of its spot and there is some oil that has spewed out of the hole where the dip stick is. And when I open the oil cap on the valve cover after a ride it has alot of suction, a big wooosh sound, so i dont understand why the dip stick shot out. Any idea on what is the problem? Thanks in advance.
Old Aug 27, 2008 | 06:31 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Question about crank vent... (RedstarS2K)
Maybe you installed it backwards? You are experiencing excessive blow by and the pressure is not being released as it should, causing crank case pressure.
At idle, you are probably not going to feel the pressure. It builds with piston speed.
Old Aug 27, 2008 | 12:56 PM
RedstarS2K's Avatar
I installed it in order to make the pressure goes to the intake pipe and the other near the pcv goes to. the intake. I dont know why the dip stick shot out it doesnt make sens. Is it backward ?
Old Aug 27, 2008 | 12:57 PM
RedstarS2K's Avatar
Is the crank vent backward?
Old Aug 27, 2008 | 02:43 PM
ricepicker's Avatar
Default Re: (RedstarS2K)
This is the direction crankcase pressure should be going... if you take off the krank vent and can't blow in to it the direction the arrows indicate, it is backwards.
Old Aug 27, 2008 | 03:20 PM
RedstarS2K's Avatar
Ok the krank vent are installed ok. I have try another time to open the oil cap and it have alot of suction but after i hit 9k a couple of time the dip stick shot out again. I dont know what to do.
Old Aug 27, 2008 | 06:32 PM
iam7head's Avatar
check it one more time, krank vent is just a one way/check valve. Try blow air one way to see if it's sealing or not
Old Aug 27, 2008 | 06:39 PM
RedstarS2K's Avatar
yes i check 2 time , but only the one near the breater pipe. I try to put only one near the pcv and the dip stick stay in place. I put the second and the problem start again. Maybe the hole on the vent are too small?
Old Aug 27, 2008 | 07:08 PM
Black S2K's Avatar
wierd sorry dont know much about crankvents im actually in the process of researching them so i cant install them on my car
Old Aug 27, 2008 | 07:21 PM
ricepicker's Avatar
Default Re: (Black S2K)
They benefit the car more when they are under a boosted application. The factory PCV isn't strong enough to withstand minor boost levels. These Krank Vents are tested to (correct me if I'm wrong) around 150 PSI. I'm not quite positive how they stop oil burning or oil consumption issues, but I had a Cusco catch can on mine, it blew smoke and burned about 1 quart of oil every 1000 miles. After I added Krank Vents inline to the catch can and the intake side, my oil consumption and smoking have disappeared.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedstarS2K &raquo;</TD></TR><TR><TD CLASS="quote">yes i check 2 time , but only the one near the breater pipe. I try to put only one near the pcv and the dip stick stay in place. I put the second and the problem start again. Maybe the hole on the vent are too small?</TD></TR></TABLE>
If the one for your PCV valve prevents your dipstick from popping out, I would suggest only running the one to your PCV valve.
Old Aug 27, 2008 | 07:27 PM
Black S2K's Avatar
^i pretty much know what they do/how they work i just havent really figured out how i would go about installing them. thanx though
Old Aug 27, 2008 | 07:43 PM
RedstarS2K's Avatar
Default Re: (ricepicker)
When i have only the one near the pcv, the oil burning start again. Whit the two, it reduce alot oil consumption. It have suction in the engine when i open the oil cap, but sometimes the dip stick shot out. I really dont understand. Also i never change the stock pcv, maybe i have to?
Old Aug 27, 2008 | 10:49 PM
ArinX's Avatar
spin ur dipstick so its facing the other way then try.
Old Aug 28, 2008 | 03:45 AM
i my honda
Global Mod
TAKE OFF THE VENTS AND SELL THEM!
You do not need them and they were not designed for this application. Put your stock PCV valve back in. You engine needs to be able to breathe in and out in the head, so you will have a bit of vacuum and a bit pressure at different points in time.
wolfcalibur
Jun 12, 2016 01:17 PM
Adam.
Sep 27, 2004 09:48 AM
Sohc Driver
May 27, 2004 06:28 AM
b20vtec-hatch
Apr 7, 2004 07:15 AM
