adjusting cam gear
Old Aug 26, 2008 | 07:45 PM
SOHC SPEED's Avatar
Default adjusting cam gear
hey guys does anybody know how many degrees i could advance the cam gear without damagind any internals, im running a D16Z6 with only a few bolt-ons, no internal work done. I have only advanced the gear 1 degree and i could feel the car running a bit better, i wanted to keep advancing but i dont know how much i could, any input would be great, thanks for your help
Old Aug 27, 2008 | 12:04 AM
HaulingAddison's Avatar
Default Re: adjusting cam gear (SOHC SPEED)
On my 90 hatch I took the belt and advanced it a whole tooth and went around and beat on it with no interferance problems. Didn't hit powerband till about 6100 RPMS though. I would probably go about half a tooths worth at most. I would just advance it another degree or 2 and see how that goes. As far as the max before interferance, I don't know.
Old Aug 27, 2008 | 04:51 AM
THC07's Avatar
can i ask why your advancing timing?
perhaps you should read about this before you keep playing with it.
http://www.team-integra.net/se...D=235
Old Aug 27, 2008 | 04:57 AM
THC07's Avatar
Default Re: adjusting cam gear (THC07)
im sorry, you said Cam timing.
https://honda-tech.com/zerothread?id=2309977
keep searching to answer all your Q.
imo, no tune means no touchy cam timing!
Old Aug 27, 2008 | 01:03 PM
blk92_d16's Avatar
Adjustable cam gears are just bling...unless you're F/I and have a tuner doing adjustments on it as needed. Even alot of the boosted setup run the factory cam gear...it's just not needed in your case. Sell it!
Ef4doorwagon
13
May 17, 2014 06:09 PM
sohcvtec91hatch
Apr 4, 2007 08:58 AM
sk8shorty012
Mar 13, 2006 11:26 AM
Ignitecivic
Nov 6, 2003 08:32 PM
Ignitecivic
Mar 15, 2002 12:32 PM
