ABS light on and off
Old Aug 26, 2008 | 07:45 PM
b18c1vtecdc2's Avatar
Default ABS light on and off
I was driving to school in the morning and i was in 4th gear at 3k rpm and all the sudden the abs came on and right before it turned off the rpm droped 1000 rpm then the light went off then the rpm came back to normal. Eversince that the abs light never came on should i be worry ?
Old Aug 27, 2008 | 05:35 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ABS light on and off (b18c1vtecdc2)
Pull the ABS code like a CEL. Just read the ABS light. There are instructions and a code list in the FAQ.
Old Aug 27, 2008 | 05:48 PM
__oversea's Avatar
i dont think you can't pull the code, unless light is on. different story by using scanner.
Old Aug 27, 2008 | 06:02 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ABS light on and off (__oversea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by __oversea &raquo;</TD></TR><TR><TD CLASS="quote">i dont think you can't pull the code, unless light is on. different story by using scanner.</TD></TR></TABLE>
You certainly can on a Gen 3. They store the last three codes. The paperclip method works.
mr_munro
Mar 14, 2012 11:53 AM
Agent Daimon
Nov 8, 2010 12:03 PM
DJLikwid
Oct 3, 2007 04:21 PM
BigChris
Jun 13, 2004 09:42 PM
