HOW DO INSTALL A DETACHABLE STERRING WHEEL AND HUB KIT ON MY 1996 CIVIC.
Old Aug 26, 2008 | 07:18 PM
JDMVILLE's Avatar
Default HOW DO INSTALL A DETACHABLE STERRING WHEEL AND HUB KIT ON MY 1996 CIVIC.
UM I BOUGHT A DETACHABLE STEERING WHEEL AND HUB KIT.
DONT KNOW HOT TO INSTALL IT. UM CAN SOMEONE JHELP ME OUT...
STEP BY STEP OR SOMETHING..THANK YOU .
Old Aug 26, 2008 | 07:23 PM
Allurian's Avatar
Default Re: HOW DO INSTALL A DETACHABLE STERRING WHEEL AND HUB KIT ON MY 1996 CIVIC. (JDMVILLE)
First and foremost CALM DOWN and then give the make and model of your detachable steering wheel and hub kit so someone can better assist you
Old Aug 26, 2008 | 07:28 PM
em1ftw00's Avatar
Remove air bag by starting with the 4 side star screws and disconnect airbag, cruise and horn pull off the one nut holding the wheel on and if its still stuck use a sterring wheel puller. if any problems visit the NRG website they use this car as the example for connecting the horn as well
Old Aug 26, 2008 | 07:37 PM
pdiggitydogg's Avatar
http://importnut.net/civicsteeringswap.htm
https://honda-tech.com/zerothread?id=2232195
https://honda-tech.com/zerothread/1887852
Old Aug 26, 2008 | 08:22 PM
JDMVILLE's Avatar
Default Re: HOW DO INSTALL A DETACHABLE STERRING WHEEL AND HUB KIT ON MY 1996 CIVIC. (Allurian)
ITS A NO BRAND. FROM EBAY.
http://cgi.ebay.com/ebaymotors...26622
Old Aug 26, 2008 | 08:24 PM
EGed up from the seat up's Avatar
its actually pretty easy to do, just follow the DIY
edit: and make sure that your wheels and steering wheel are straight before you take it apart
Old Aug 26, 2008 | 09:10 PM
ek99si's Avatar
This should help
http://www.jdmuniverse.com/for...73902
Old Aug 26, 2008 | 09:24 PM
Shaynepolevault's Avatar
Default Re: HOW DO INSTALL A DETACHABLE STERRING WHEEL AND HUB KIT ON MY 1996 CIVIC. (ek99si)
i had a friend that ordered from nana outpost same place you ordered and got that same product. you should really sale that and buy some nrg or worksbell. spend the little extra money because those things are cheap, last thing you would want is driving on the freeway and your wheel pops off. But good luck anyways.
Old Oct 2, 2008 | 07:09 PM
khmer_gentleman's Avatar
Default Re: HOW DO INSTALL A DETACHABLE STERRING WHEEL AND HUB KIT ON MY 1996 CIVIC. (Shaynepolevault)
did you get it installed? how is it?
phoshizzle88
Sep 12, 2006 07:46 AM
Trippsol
Jun 13, 2006 06:38 PM
Mistermark
Mar 6, 2006 11:46 AM
all_motoref9
Jun 28, 2004 06:28 AM
servion
Feb 4, 2002 05:59 AM
