Help! Replacing Distributor Problem!
Old Aug 25, 2008 | 09:09 PM
jrxiongs's Avatar
Default Help! Replacing Distributor Problem!
Hi! I have a 93 civic with a d16z6 motor, the CEL came on with the code 9 (Cyclinder Sensor). I was told that it was the distributor. I Replaced my distributor and my car wont start no more! Whys this? I already set my timing and lined it up right! When I start my engine my distributor shakes or moves! Can anyone help me out plz?
Old Aug 25, 2008 | 09:25 PM
19ekcoupe96's Avatar
Default Re: Help! Replacing Distributor Problem! (jrxiongs)
have you tried rotating the distributor 180 degrees??
Old Aug 25, 2008 | 09:28 PM
Frozen E's Avatar
H-T White Ops
Default FV-QR
Not sure if it's possible with the Z6, but make sure you didn't install your distributor 180 degrees out of time. Pull it back off, turn it 180 degrees and reinstall. Again, I'm not sure if it's even possible since most distributors have notched shafts that can only be installed one way.
A shaking and moving distributor sounds to me like it's not seated properly (see comment above about the notched shaft).
Old Aug 26, 2008 | 07:59 AM
92dxh22turbo's Avatar
if you haven't tried this take off cap and turn rotor to number one cylinder
Old Aug 26, 2008 | 08:09 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Help! Replacing Distributor Problem! (19ekcoupe96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19ekcoupe96 &raquo;</TD></TR><TR><TD CLASS="quote">have you tried rotating the distributor 180 degrees??</TD></TR></TABLE>
The dist to cam connection is off-set. If you have it 180 off, the dist will shake badly and the car wont start
Old Aug 26, 2008 | 08:17 AM
94EG8's Avatar
Seagull Management
Default Re: Help! Replacing Distributor Problem! (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrxiongs &raquo;</TD></TR><TR><TD CLASS="quote">When I start my engine my distributor shakes or moves!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">The dist to cam connection is off-set. If you have it 180 off, the dist will shake badly and the car wont start</TD></TR></TABLE>
Hmm, i think there may be a corolation here. Evs-one is right, the two pronged cam on the end of the distributor is offset slightly to once side so that theoratically at least its impossible to get it on wrong, that said if you try hard enough you can probably still get it on there.
Old Aug 26, 2008 | 08:23 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Help! Replacing Distributor Problem! (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">
Hmm, i think there may be a corolation here. Evs-one is right, the two pronged cam on the end of the distributor is offset slightly to once side so that theoratically at least its impossible to get it on wrong, that said if you try hard enough you can probably still get it on there.</TD></TR></TABLE>
I've seen it more than once- and the dist will shake violently
Old Aug 26, 2008 | 03:03 PM
jrxiongs's Avatar
hmm...I took out the distributor and put it back in and turned it 180 degree..Now the distributor wont go all the way in??? whats the problem now? Is it because of my camshaft?
Old Aug 26, 2008 | 03:06 PM
Frozen E's Avatar
H-T White Ops
Default FV-QR
Did you get the right one?
warfield21
Apr 15, 2017 12:26 PM
jdmkidd23
11
Nov 17, 2008 08:54 AM
irishgod247
Mar 13, 2007 10:35 AM
IntegD
Apr 2, 2004 10:16 AM
