leaking oil through headers?
Old Aug 25, 2008 | 06:51 PM
elmejor's Avatar
Default leaking oil through headers?
can someone explained to me why im leaking oil through my headers, im also losing atifreeze without overheating i have no leaks on any of my hoses, what can be the problem?
Old Aug 25, 2008 | 06:54 PM
sageuvagony's Avatar
Default Re: leaking oil through headers? (elmejor)
You have only 1 header, and is it oil or like unburnt greasy sooty crap? Perhaps you have a bad exhaust gasket or a bad valve cover gasket which is allowing oil to drip down?
I remember when my go-ped (motorized scooter thingy) would have lots of black oil looking crap coming out of the exhast manifold but that was because I had it installed without an exhaust gasket.
If that's really engine oil, you don't want that crap to catch fire which is very possible.
Old Aug 25, 2008 | 07:10 PM
elmejor's Avatar
Default Re: leaking oil through headers? (sageuvagony)
do i have to replace head gasket
Old Aug 25, 2008 | 07:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmejor &raquo;</TD></TR><TR><TD CLASS="quote">do i have to replace head gasket</TD></TR></TABLE>
Head gasket jumping way ahead at the moment. Just try to pinpoint exactly where it's coming. It could be from the valve cover gasket or the exhaust/header gasket itself. Remove the header and see if there's oil all over.
Did you mean to say header gasket or you really meant head gasket?
Old Aug 25, 2008 | 07:14 PM
Unseen Racer's Avatar
you got a busted gasket.
replace the gasket and everything should be ok.
i would replace the header gasket and the cam gasket aswell while your at it.
cuz it can also be that the cam gasket is busted at the front and its leaking and dripping down to the headers
Old Aug 25, 2008 | 07:18 PM
Default Re: leaking oil through headers? (Unseen Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unseen Racer &raquo;</TD></TR><TR><TD CLASS="quote">you got a busted gasket.
cuz it can also be that the cam gasket is busted at the front and its leaking and dripping down to the headers</TD></TR></TABLE>
Old Aug 25, 2008 | 07:19 PM
elmejor's Avatar
yeah i meant head gasket, cause im also smoking black though my exhaust and losing atifreeze without any leaks to be seen
Old Aug 25, 2008 | 07:21 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default FV-QR
a pic is worth a thousand words. especially when we don't really know what you are talking about.
smoking black?
maybe your combustion chamber is burning oil.
Old Aug 25, 2008 | 07:22 PM
and your losing anti freeze?
well the only way you can lose anti freeze is if you have a leak.
some 1 correct me if im wrong.
Old Aug 25, 2008 | 07:33 PM
jay-d-em's Avatar
i had the same problem. i broke my head with it too. i thought is was my guides and seals so i got the head fully rebuilt. i threw it back on and i still had the same problem so i ripped it apart again and i found the problem. it was my oil rings on the number 4 piston. it scratched the cyl. wall enough for oil to shoot up into my exhaust valves and leak right out. oil was only coming out the #4 exhaust only.
Old Dec 10, 2012 | 06:30 PM
boonetunedh22's Avatar
was your spark plug on cyl 4 gunked up as well
Old Dec 11, 2012 | 09:22 PM
beyond305's Avatar
could be his valve cover isnt screwed down tight enough, i have this same problem..looks like oil coming from the header but if you follow it, comes from the VC. my VC has two stripped bolts though, gotta be careful when tightening them.
Old Dec 11, 2012 | 09:35 PM
CO671's Avatar
Yeah it could be like that too.
This thread was from 2008 btw.
Old Dec 12, 2012 | 02:30 AM
sk8member's Avatar
If you have oil on your exhaust manifold. It is probably dripping down the valve through the seal, which means you might want to look at the valve steam guide seal. If you are leaking or burning coolant, it is a headgasket, cracked block, cracked head.
gooblinn258
Feb 12, 2014 04:51 AM
brandonEM1
Apr 10, 2009 05:01 AM
Adankid
14
Sep 7, 2008 06:14 AM
EkFG
Mar 15, 2008 07:47 PM
spender1326
Jun 24, 2005 06:41 PM
