crankshaft position sensor problem
Old Aug 25, 2008 | 04:33 PM
civicsi_5289's Avatar
Default crankshaft position sensor problem
I have a JDM B16a with a OBD I phareable chipped ecu. My check engine light came on and says that the crankshaft is misaligned and cylinder three is out of line. I did re-search and I found that that motor does not have a crankshaft position sensor and that it could be something with the distributor. Any ideas one what I can do to fix this problem?
Old Aug 25, 2008 | 04:47 PM
slowcivic2k's Avatar
Default Re: crankshaft position sensor problem (civicsi_5289)
Your crank sensor is in the distributor, search and you will learn more.
Check your wiring from the distributor to the ECU, Polarity counts, if they are reversed, you will have a problem.
Old Aug 25, 2008 | 04:49 PM
Default Re: crankshaft position sensor problem (slowcivic2k)
Thanks is there any way that there could be something wrong inside the distributor it self?
Old Aug 25, 2008 | 09:36 PM
dtapia's Avatar
anything could be wrong from a faulty wiring bad icm bad dist assy .
easymac
14
Oct 1, 2009 04:16 PM
raidacaipo
May 18, 2009 08:57 AM
Brandoff
Nov 19, 2008 04:29 AM
YellowR2000x2
Mar 4, 2005 04:29 PM
B16pwrHB
10
Sep 21, 2002 02:59 PM
