Over heating need help
Old Aug 25, 2008 | 08:39 AM
Lipan90crx's Avatar
Default Over heating need help
I have a 92 civic hatch with a 95 ls motor It had a blown head gasket got that done resurfaced every thing new water pump thermostat radiator and its still over heating can someone help me out im running out of ideas Thanks for anything
Old Aug 25, 2008 | 09:58 AM
rivaladore's Avatar
Default Re: Over heating need help (Lipan90crx)
is your radiator fan turning on at all? Is it overheating on the highway or just in traffic/city driving?
Old Aug 25, 2008 | 11:14 AM
Lipan90crx's Avatar
Default Re: Over heating need help (rivaladore)
It idles fine the fan works but its on a switch and no didnt forget to turn it on or off you can run it for like 20 or 30 min. and its highway or cruzing if i gas on it it will cool down alittle then it just goes right back up
Old Aug 26, 2008 | 02:29 PM
Lipan90crx's Avatar
Still need help still
Old Aug 27, 2008 | 12:41 AM
HaulingAddison's Avatar
when the car starts to over heat, do you turn the heat on to see if it's kicking heat out? It could be you have a bad, leaking, or cloged heater core. I would start by looking for water by the heater core. If there's no water, try to some how clean out the heater cores inside (or replace it). After that, I don't know. Try taking the thermostate out and running it to see if it still overheats.
manuel12
May 12, 2010 09:22 AM
white98gs-r
Apr 5, 2009 06:51 AM
games666
Dec 7, 2008 07:36 PM
civic_22
Jun 16, 2008 01:01 PM
Gabe_
12
Jun 13, 2003 02:47 AM
