I found this neato Wiki
Old Aug 25, 2008 | 06:31 AM
HondaHeddie's Avatar
Default I found this neato Wiki
I had never thought of Wikipedia for Honda info but here it is.
I post it for accuracy checking by those who know better.
http://en.wikipedia.org/wiki/Honda_D_engine#D15B7
Old Aug 25, 2008 | 07:24 AM
KB91Hatch's Avatar
Default Re: I found this neato Wiki (HondaHeddie)
thats awesome! good ole Wiki
Old Aug 25, 2008 | 08:31 AM
beana's Avatar
i found something err, interestinger from wiki
B16B (civic Type R)
VTEC
Found in:
1997-2000 Civic Type R[EK9]
Displacement: 1595 cc
Compression: 10.8:1
Bore: 81 mm
Stroke: 77.4 mm
Rod/Stroke ratio: 1.84:1
Rod Length: 142.42 mm (5.607")
Power: 180 hp (134 kW) @ 8200 rpm & 115 ft·lbf (155 Nm) @ 7500 rpm
Redline: 9200 rpm
Transmission: S4C With LSD
0-80 High 5's
Note: This engine uses the same block as the Integra Type R, which is taller than the B16a block, but with a crank the same stroke as the b16a. It uses longer rods to accommodate for this, which is why the Rod/Stroke ratio is higher than a standard B16
Old Aug 25, 2008 | 08:56 AM
scottmog's Avatar
yea isnt it great? i found that a while back too
Old Aug 25, 2008 | 09:57 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: I found this neato Wiki (Mog)
I loved when they had a d14z8.... a supercharged sohc vtec found only in ek9 hatches in the uk kinda makes me want to never look at wiki again.
swizz977
Jul 24, 2010 06:26 PM
Team RS2
Jun 4, 2007 05:05 AM
theneil
Aug 22, 2003 05:29 PM
tECH_
Jun 5, 2002 07:05 PM
H22CIVIC
Oct 1, 2001 03:30 PM
