B17 b16a diffrences?
Old 06-03-2007, 12:02 PM
Team RS2's Avatar
Default B17 b16a diffrences?
what are the diffrences, need quick naswers
is the head a PR3 casting?
block diffrences?
DA gsr correct?
Old 06-03-2007, 01:03 PM
been there done that
doood's Avatar
Default Re: B17 b16a diffrences? (Team RS2)
crank
rods
pistons
cams
ecu
everything else is the same or nearly identical
Old 06-03-2007, 01:27 PM
Go Tigers!
Bense's Avatar
Default Re: B17 b16a diffrences? (doood)
b16
77.4mm stroke
137mm rod
b17 (same block as b16
81mm stroke
132mm rod
Old 06-03-2007, 01:40 PM
Ek Forever y0!
Libertariat's Avatar
Default Re: B17 b16a diffrences? (Bense)
B17A1
VTEC
Found in:
1992-1993 Integra GS-R (DB2)
Displacement: 1678 cm³
Compression: 9.6:1
Power: 160 hp @ 7600 rpm & 117 ft·lbf (159 N·m) @ 7000 rpm
Transmission: Cable~ YS1
B16A2
VTEC
1992-2000 Honda Civic EDM VTi (EG & EK)
Displacement: 1595 cm³
Compression: 10.2:1
Power: 160 hp @ 7600 rpm & 113 ft·lbf (153 N·m) @ 7300 rpm
Transmission: Y21
1999-2000 Honda Civic Si (EM1)
Compression: 10.2:1
Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
Transmission: Y21 S4C
1996-1997 Honda Del Sol VTEC (EG)
Compression: 10.4:1
Power: 160 hp (119 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
Transmission: Y21
Old 06-03-2007, 10:28 PM
Team RS2's Avatar
Default Re: B17 b16a diffrences? (ek forever guy)
ok ty for the info dudes, i didnt have time to repl but we went to the junkyard and we snagged a b17a1 from a totaled GS-R and a p30 ecu from a b16 sol, no plans yet but im shelving all these parts i heard they are somewhat rare, and you cant even get a b16 for the 500 bucks i laid down for both of these, the car was actually running at the salvage yard, *** end wreck
Old 06-03-2007, 10:32 PM
cycoclown's Avatar
next thing you should do is build a junkyard turbo haha
Old 06-03-2007, 10:36 PM
Donkey85's Avatar
Default Re: B17 b16a diffrences? (cycoclown)
what type of trans did they use on that motor? is it the same egearing as the b16 also?
Old 06-03-2007, 10:47 PM
Team RS2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cycoclown &raquo;</TD></TR><TR><TD CLASS="quote">next thing you should do is build a junkyard turbo haha </TD></TR></TABLE>
looks at ej1 in garage, yea been there done that, but used parts and homedepot for boost guage, accssories, oil fittings and stainless ftw
screw -an fittings,
hit up the toiletry aisle, buy stainless yards and end caps !!!!!!!
Old 06-04-2007, 04:59 AM
Go Tigers!
Bense's Avatar
Default Re: B17 b16a diffrences? (Donkey85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">what type of trans did they use on that motor? is it the same egearing as the b16 also?</TD></TR></TABLE>
it's a cable trans that has "upgraded" components. These components found their way into the hydro trans.
It's just like the hydro b16/4.4 itr trans, but it has a slightly shorter 1st and 5th.
b17 cable trans is the ideal cable b-series trans to have.
Old 06-04-2007, 05:05 AM
Ek Forever y0!
Just fyi you're looking for a cable tranny stamped YS1
swizz977
07-24-2010 06:26 PM
HondaHeddie
08-25-2008 09:57 AM
joey funk
06-19-2007 02:52 PM
pompom
10
09-15-2006 04:16 PM
Quick Reply: B17 b16a diffrences?
