d16z6...rebuild it?
Old Aug 25, 2008 | 12:36 AM
DCRB's Avatar
Default d16z6...rebuild it?
So i bought this D16Z6 from a friend of a friend. it was out of a 95 civic hatch. supposedly has rougly 110,xxx on it. but i was pulling it apart, and was noticing that cylinder 4 was completely rusted up (it was clost to bdc, 2 and 3 were clost to tdc). so i tear the bottom end out, and get the pistons taken out. found a nice milk shake in the oil pan... any ways got 2 and 3 pulled out, found out that previous owner blew the HG on cylinders 2,3, and 4. i think it's cuz the water pump was siezed up. so i'm looking at 3 pistons w rings rusted in them, and cuz my friend kind of attacked one rod w a screw driver to try to get the bottom race on the rod out i'm looking @ new rod bearings as well (which looked BRAND NEW before they were scored up w a screw driver.)
so the pistons/rods/crank/w/e is re-useable. rings are gone. bearings are being replaced. should i take a small honing tool to the block to clean the rust out? or just attack it w brake cleaner, machine oil and a soft sos pad? don't really wanna go mini me
p.s. thanks in advance, just need some advice
Old Aug 25, 2008 | 04:56 AM
MyHotsh's Avatar
Default Re: d16z6...rebuild it? (DCRB)
If you have it apart already just get it rehoned and rebuild with all new bearings and gaskets.
That way you know its a fresh motor going in your car.
good luck!!!
Old Aug 25, 2008 | 03:24 PM
DCRB's Avatar
Default Re: d16z6...rebuild it? (MyHotsh)
word that's what my friend said. I'm going to honda here in a few to get prices for berings, rings, a drivers side door seal, and then autozone for some brake cleaner (a grip) and some gasket prices.
any one know where they sell machinests strait edges? i have a weird feeling that my head might be warped... they guy was running a metal HG, and w a siezed up water pump i can't help but think it was over heated hella cuz the head had marks where wate was leaking between the head and the gasket, but being that it's a metal hg and not a graphite one (like what i have) it didn't brake the gasket....
we'll see how this build goes. the only experince i have w motor swaps is w a jetta when i was 5, and then a lawnmower engine i rebuilt last year in school that ran GREAT when i was done (as apposed to not at all before... ) and when i showed up a class on how to rebuild car engines. good thing i know what all to measure and check for tho
dual_turbo30
Aug 22, 2017 06:29 AM
cityofcaterpillars
Engine Machining & Assembly
Jul 19, 2016 05:10 AM
Don Jefe
Feb 22, 2013 10:34 AM
sodacan33
Jun 10, 2004 07:10 AM
B18C-RnVA
Jul 14, 2002 04:34 AM
