02 sensors B16A
Old Aug 24, 2008 | 08:59 PM
doom26464's Avatar
Default 02 sensors B16A
ok so finally got a proper stock mainfold with 2 o2 bungs and put my 1 wire o2 sensors in(car had No 02 sensors for the last 3 months and was getting [cruddy] gas mileage). Now there where 2 wires dangling out of the engine harness there where cut that where both yellow I assumed they where for the 02 sensors. so i connected them up and took the car for a drive. it drove sorta of the same expect sometime when i hold the throttle very still and just cruze and then go to floor it it kind of hesitats then goes. Thought I had them mixed up and switched the 2 wires around and made no difference. I always thought that if you had the wires mixed up the car drives funny. Made no difference witch way I put the wires. I took a power tester to the wires and got no power of it at all(tried reving it and still nothing). not sure how much volt goes threw it but Is there a way to diagnose it with a volt meter? My next best guess is im going to see if it changes my gas mileage at all then if not going to try and wire them straight to the ECU.
any insight or ideas?
Old Aug 24, 2008 | 09:32 PM
vtecb18c's Avatar
Default Re: 02 sensors B16A (doom26464)
and CEL?
Old Aug 24, 2008 | 09:56 PM
doom26464's Avatar
Default Re: 02 sensors B16A (vtecb18c)
yes it is getting CEL sometime under full thortle or just letting off the throtlle after cruzing. I have no idea how to check the codes though on this car.
It only comes on though like once and every while not very often.
Old Aug 24, 2008 | 10:12 PM
vtecb18c's Avatar
https://honda-tech.com/zerothread/1901557
Old Aug 24, 2008 | 11:13 PM
doom26464's Avatar
can't find this plug? also that shows for obd-1 and obd-2 cars i have an obd-0 car
Old Aug 25, 2008 | 09:31 AM
doom26464's Avatar
bump
Old Aug 25, 2008 | 12:02 PM
gringo7718's Avatar
Default Re: (doom26464)
Wire your O2 sensors directly to the ECU as shown. Don't forget to clear the codes from your ECU or else you will still have a CEL. If you still have problems it is either bad O2 sensors, bad wiring, or a bad ECU.
https://honda-tech.com/zerothread?id=900501
Old Aug 25, 2008 | 12:03 PM
crxhondata's Avatar
Default Re: (gringo7718)
bump for this
Old Aug 25, 2008 | 12:05 PM
gringo7718's Avatar
Default Re: (crxhondata)
This is located in the FAQ!
Old Aug 25, 2008 | 08:58 PM
doom26464's Avatar
im aware its located in the FAQ thats how i figured out how to put the o2 sensors in. Going to wire it straight to the ecu and see if that helps
Old Aug 26, 2008 | 05:02 PM
doom26464's Avatar
the diagram listed for the ECU pinouts shoudl work on a PR3 -J00 (92 JDM integra ECU) correct?
Old Aug 26, 2008 | 05:12 PM
SIred91's Avatar
Rainman
correct
Old Aug 26, 2008 | 06:11 PM
doom26464's Avatar
k thnx alot Wierd it up right to the ecu. Seems like the previous owner had done something wierd as the wires where spliced into some other random wire. so cut them and spliced them into my wires straight to the 02 sensors. Fired it up and took it for a drive. Car drives much better seems alot more smoother to drive and no hesitating. Took it on the highway though and did some light cruzing and i got a check engine light still. Car drives much better but still randomly getting check engine. I really wish I could figure out how to check codes on this thing but I can't seem to find the plug where you put the paper clip in
Old Aug 26, 2008 | 06:20 PM
sgallagher's Avatar
If you've got a PR3 ECU it should have a light on the ECU which will blink the code stored with the key in the on position.
Old Aug 26, 2008 | 06:26 PM
doom26464's Avatar
Default Re: (sgallagher)
thank you very much! i will make a new thread to help diagnose the code
Romo Pyro
11
Aug 15, 2008 07:48 PM
Achenar
12
Dec 30, 2005 09:17 PM
yusoslo
May 17, 2004 07:00 AM
94si94cx
Apr 30, 2003 03:59 PM
Turbo88hatch
Feb 16, 2003 09:21 AM
